In Betweeno to Excel
Hello all,
I have been having issues with in betwino. Being quite new to the arduino language, there is quite a lot of things I had to learn (in a very limited time frame) and I appear to be stuck. Me and some of my friends are using I2C with the BMP208 and the MPU-6050, but I am out of ideas on how to output that information out onto an edexcel spreadsheet. Any help is greatly appreciated!
What would that be? I've heard of GoBetuino.
Well, it is likely to involve a change to the code you posted. Oh, wait, you didn't. Why not? When you read the stickies that you were supposed to read before posting here, you were told to post your code. You DID read the stickies, right?
I think there is an example called:
gobetwinoXLtest
I have not tried it yet.
PaulS:
What would that be? I’ve heard of GoBetuino.
Well, it is likely to involve a change to the code you posted. Oh, wait, you didn’t. Why not? When you read the stickies that you were supposed to read before posting here, you were told to post your code. You DID read the stickies, right?
Sorry, was working with another guy he’s quite ‘protective’ when it comes to his code, don’t ask why. If you need it, here it is:
// MPU-6050 Start Initializing
#include<Wire.h>
const int MPU=0x68;  // I2C address of the MPU-6050
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
// MPU-6050 Finished Initializing
//BMP208 Start Initializing
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h> //please ensure library installed correctly
#include <Adafruit_BMP280.h> //please enaure library installed correctly
#define BMP_SCK 13
#define BMP_MISO 12
#define BMP_MOSI 11
#define BMP_CS 10
Adafruit_BMP280 bme; // I2C
char values[10];
//These variables will be used to hold the x,y and z axis accelerometer values.
int x,y,z;
//ADXL345 Stop initializing */
void setup(){
//BMP208 Start setup
  Serial.println(F("Program start"));
  if (!bme.begin()) {
    Serial.println("Error, sensor not found!");
    while (1);
//BMP208 Stop setup
//MPU-6050 Setup start
  Wire.begin();
  Wire.beginTransmission(MPU);
  Wire.write(0x6B);  // PWR_MGMT_1 register
  Wire.write(0);     // set to zero (wakes up the MPU-6050)
  Wire.endTransmission(true);
//MPU-6050 Setup Stop
void loop(){
//MPU-6050 Program start
  Wire.write(0x3B);  // starting with register 0x3B (ACCEL_XOUT_H)
  Wire.endTransmission(false);
  Wire.requestFrom(MPU,14,true);  // request a total of 14 registers
  AcX=Wire.read()<<8|Wire.read();  // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
  AcY=Wire.read()<<8|Wire.read();  // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
  AcZ=Wire.read()<<8|Wire.read();  // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
  Tmp=Wire.read()<<8|Wire.read();  // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
  GyX=Wire.read()<<8|Wire.read();  // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
  GyY=Wire.read()<<8|Wire.read();  // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
  GyZ=Wire.read()<<8|Wire.read();  // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
  Serial.print("AcX = "); Serial.print(AcX);
  Serial.print(" | AcY = "); Serial.print(AcY);
  Serial.print(" | AcZ = "); Serial.print(AcZ);
  Serial.print(" | Tmp = "); Serial.print(Tmp/340.00+36.53);  //equation for temperature in degrees C from datasheet
  Serial.print(" | GyX = "); Serial.print(GyX);
  Serial.print(" | GyY = "); Serial.print(GyY);
  Serial.print(" | GyZ = "); Serial.println(GyZ);
//MPU-6050 Program Stop
//BMP208 Program start
  Serial.print("Temperature = "); Serial.print(bme.readTemperature()); Serial.println(" *C");
    Serial.print("Pressure = ");
    Serial.print(bme.readPressure());
    Serial.println(" Pa");
    Serial.print("Approx altitude = ");
    Serial.print(bme.readAltitude(1013.25)); // this should be adjusted to your local forcase
    Serial.println(" m");
//BMP_208 Prpgram stop
//Main delay
When that code is running, what is GoBetwino showing?
