In deeper trouble after attempting file purge to fix error
Here is what happened in a nutshell:
I let my brother use my laptop to work on an arduino programming project of his, and I don't know what he did exactly but every time I tried to upload a program from the IDE to my board, I would get this error:
espcomm_upload_mem failed. There was also something about exceeding some kind of memory limit but I do not understand what or where or why this is (I am only minimally computer literate :confused: )
My attempts to understand what was going on thru the magic of googling ended up fruitless.
I do not have screenshots of the error unfortunately and am unable to make one because of what I have tried to do in an attempt to fix the original problem: first I tried uninstalling and re-installing the IDE, but the error kept coming up. So I figured it must have something to do with the other files that the IDE uses on my computer, and so I proceeded to delete every file I could find having to do with arduino. There are still a few left but these require system permission so I figured it's probably best to leave them be. I thought I would be able to re-install with a clean slate after this, but when I attempt to run the installer via this site, it says I already have it and it needs to be uninstalled. When I try to uninstall it, it says the uninstaller cannot be found. I guess I must have deleted it.
Attached is a screenshot of what the installer says and what my operating system says when I do this.
There are sometimes remnants of installs.
Hopefully the attached file is of some help in that regards..
CLEAN UP BEFORE INSTALLING ANOTHER COPY OF THE IDE OR ARDUINO CREATE.pdf (345 KB)
Thanks for that guide.
90%+ of non-driver installation issues are fixed by uninstall, delete arduino15 folder, reinstall. Deletion of registry keys is not normally required.
Thanks kind sir or madam to you both. I will try what you have suggested on the morrow.
