In defense of L298N / looking for alternatives
So, I get that you all hate the L298N, and I get why. The thing is:
  • It's easy: wire up power, ground, motor wires, and you're done
  • It's not a shield: it doesn't assume you're gonna plug it into an Uno, so it's great for i.e. Nano-based projects
  • It's quick: as a self-contained board, I don't have to start my project with a bunch of soldering
  • It's cheap: I've found working ones on Aliexpress for < $2
Having said all that, obviously the inefficiency / power consumption is the big Achilles heel that has me looking for an alternative. I'm working on a project that needs to be mobile and I'd like it to not burn through batteries as quickly.
Specifically, I'm driving 2 5v DC motors under moderate load (the weight of all the components, plus batteries) + powering a Nano & a couple sensors.
Any suggestions that meet the above criteria, or are at least within the ballpark? Thanks in advance.
I replace that old turkey with TB6612FNG
I've looked at that. In terms of my criteria, are you saying buy the standalone IC and plug it into a breadboard? (The only board version I've seen with soldered headers is from Sparkfun for $13—yuck).
I will dare to suggest something outside the ballpark, just because I have been using it for a project that has almost the same requirements and I´m quite happy.
This board is called Vespa (Wasp) and it´s based on the DRV8837, integrated on an ESP32 board. It´s not cheap (~US$35,00) but you have all you need in one board + bluetooth or wi-fi comms.
This board is sold in Brazil, but maybe you can find something similar outside there. No need for breadboards. Holes are Uno compatible.
On Amazon.CA 2 for $10, about $7 USD, and on AliExpress, 3 for $1.73 CDN with free shipping.
Just solder the headers on.
I specifically mentioned 'no soldering' in my criteria because I do a lot of work with young students, so soldering is a non-starter.
Is it possible to plug the IC by itself into a breadboard?
I did find with hdrs on Ali, but price rises to $1.87USD each, free shipping.
https://www.aliexpress.com/item/1005006746785700.html?spm=a2g0o.productlist.main.43.3c977xAu7xAuMK&algo_pvid=2067d277-607a-4920-9ed4-ccf161a5ea58&algo_exp_id=2067d277-607a-4920-9ed4-ccf161a5ea58-21&pdp_npi=4%40dis%21CAD%212.74%212.60%21%21%2113.99%2113.27%21%402103237317227282337901954e6a5e%2112000038172030110%21sea%21CA%212466905694%21X&curPageLogUid=Sa8gxxnH6Rvc&utparam-url=scene%3Asearch%7Cquery_from%3A
Very cool. I'll try that one out. Thanks.
Pololu has a good selection of quality, modern motor driver boards, take a look at the summary including current/voltage ratings.
Hmmm... I learned to solder when I was 5 (or maybe 6)
