Hello there,
I am working on combining three codes(RC, HRSC04, GPS), where Remote Control and ultrasonic codes combining didn't give me any problem as it worked (named it as HRSC04_RC). But, adding GPS code to the HRSC04_RC giving me an error. I believe Software serial and enable interrupt libraries won't work together.
Can anyone give me the solution to it, how to avoid the error?
#include <EnableInterrupt.h>
long loop_timer, tiempo_ejecucion;
volatile long contPotenciaInit; // RC POTENCIA
volatile int PulsoPotencia;
volatile long contPitchInit; // RC PITCH
volatile int PulsoPitch;
volatile long contRollInit; // RC ROLL
volatile int PulsoRoll;
volatile long contYawInit; // RC YAW
volatile int PulsoYaw;
//HRSC04/////
float altura, alturaFilt;
bool initHC = true;
volatile float PulsoAlt;
volatile long contAltInit;
///GPS ///
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
// Choose two Arduino pins to use for software serial
int RXPin = 7;
int TXPin = 8;
int GPSBaud = 115200;
// Create a TinyGPS++ object
TinyGPSPlus gps;
// Create a software serial port called "gpsSerial"
SoftwareSerial gpsSerial(RXPin, TXPin);
///HRSC_04///////
pinMode(18, INPUT_PULLUP); // Echo
pinMode(A3, OUTPUT); // Trg
enableInterrupt(18, INTalt, CHANGE);
//RC///////////
pinMode(21, INPUT_PULLUP); // YAW
enableInterrupt(21, INTyaw, CHANGE);
pinMode(20, INPUT_PULLUP); // POTENCIA
enableInterrupt(20, INTpotencia, CHANGE);
pinMode(3, INPUT_PULLUP); // PITCH
enableInterrupt(3, INTpitch, CHANGE);
pinMode(2, INPUT_PULLUP); // ROLL
enableInterrupt(2, INTroll, CHANGE);
/////GPS SET UP/////
gpsSerial.begin(GPSBaud); // Start the software serial port at the GPS's baud
////RC INTERRUPTS///
void INTyaw() {
if (digitalRead(21) == HIGH) contYawInit = micros();
if (digitalRead(21) == LOW) PulsoYaw = micros() - contYawInit;
void INTpotencia() {
if (digitalRead(20) == HIGH) contPotenciaInit = micros();
if (digitalRead(20) == LOW) PulsoPotencia = micros() - contPotenciaInit;
void INTpitch() {
if (digitalRead(3) == HIGH) contPitchInit = micros();
if (digitalRead(3) == LOW) PulsoPitch = micros() - contPitchInit;
void INTroll() {
if (digitalRead(2) == HIGH) contRollInit = micros();
if (digitalRead(2) == LOW) PulsoRoll = micros() - contRollInit;
///////HR-SC04////
void INTalt() {
if (digitalRead(18) == HIGH) contAltInit = micros();
if (digitalRead(18) == LOW) {
PulsoAlt = micros() - contAltInit;
initHC = true;
while (micros() - loop_timer < 6000);
loop_timer = micros();
HCSR04();
Serial.println(alturaFilt);
/////RC///////
while (micros() - loop_timer < 10000);
tiempo_ejecucion = (micros() - loop_timer) / 1000;
Serial.print(PulsoPotencia);
Serial.print("\t");
Serial.print(PulsoPitch);
Serial.print("\t");
Serial.print(PulsoRoll);
Serial.print("\t");
Serial.println(PulsoYaw);
//GPS LOOP//
// This sketch displays information every time a new sentence is correctly encoded.
while (gpsSerial.available() > 0)
if (gps.encode(gpsSerial.read()))
displayInfo();
///////HR-SC04////
void HCSR04() {
if (initHC == true) {
alturaFilt = PulsoAlt * 0.01715;
alturaFilt = alturaFilt * 0.8 + PulsoAlt * 0.01715 * 0.2;
analogWrite(A3, 255); // A3 HIGH
delayMicroseconds(10);
analogWrite(A3, 0); // A3 LOW
initHC = false;
//////gps diplay info/////
void displayInfo()
if (gps.location.isValid())
Serial.print("Latitude: ");
Serial.println(gps.location.lat(), 6);
Serial.print("Longitude: ");
Serial.println(gps.location.lng(), 6);
Serial.println("Location: Not Available");
After compiling, it says:
E:\temp\arduino_build_848242\libraries\SoftwareSerial\SoftwareSerial.cpp.o (symbol from plugin): In function `SoftwareSerial::read()':
(.text+0x0): multiple definition of `__vector_9'
E:\temp\arduino_build_848242\sketch\hr_sco4_new_sketch_try_with_gps.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `__vector_10'
(.text+0x0): multiple definition of `__vector_11'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Mega or Mega 2560.
Thank you!
