In member function ‘int8_t RobotControl::keyboardRead()’: - New but Nokia 5110
Hello! Im using Arduino 1.04 with board ATmega328 on board (8 mhz) and not 16 mhz.
When i compile this code i got this error. Why?
Yes i have the Adafruit_GFX and Adafruit_PCD8544 library.
acer@Parrot:/usr/share/arduino/libraries$ cd Robot_Control
acer@Parrot:/usr/share/arduino/libraries/Robot_Control$ ls
Adafruit_GFX.cpp EEPROM_I2C.cpp information.cpp Sensors.cpp
Adafruit_GFX.h EEPROM_I2C.h keyboard.cpp SPI.cpp
Arduino_LCD.cpp examples lcd.cpp SPI.h
Arduino_LCD.h Fat16Config.h Melody.cpp Squawk.cpp
ArduinoRobot.cpp Fat16.cpp Motors.cpp Squawk.h
ArduinoRobot.h Fat16.h Multiplexer.cpp SquawkSD.cpp
communication.cpp Fat16mainpage.h Multiplexer.h SquawkSD.h
Compass.cpp Fat16util.h RobotSdCard.cpp utility
Compass.h FatStructs.h SdCard.cpp Wire.cpp
EasyTransfer2.cpp glcdfont.c SdCard.h Wire.h
EasyTransfer2.h helper.cpp SdInfo.h
acer@Parrot:/usr/share/arduino/libraries/Robot_Control$ cd ..
acer@Parrot:/usr/share/arduino/libraries$ cd Adafruit_GFX
acer@Parrot:/usr/share/arduino/libraries/Adafruit_GFX$ ls
Adafruit_GFX.cpp Adafruit_GFX.h glcdfont.c license.txt README.txt
acer@Parrot:/usr/share/arduino/libraries/Adafruit_GFX$ cd ..
acer@Parrot:/usr/share/arduino/libraries$ cd Adafruit_PCD8544
acer@Parrot:/usr/share/arduino/libraries/Adafruit_PCD8544$ ls
Adafruit_PCD8544.cpp Adafruit_PCD8544.h examples license.txt README.txt
This is an example sketch for our Monochrome Nokia 5110 LCD Displays
  Pick one up today in the adafruit shop!
  ------> http://www.adafruit.com/products/338
These displays use SPI to communicate, 4 or 5 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada  for Adafruit Industries.
BSD license, check license.txt for more information
All text above, and the splash screen must be included in any redistribution
#include <Adafruit_GFX.h>
#include <Adafruit_PCD8544.h>
// pin 7 - Serial clock out (SCLK)
// pin 6 - Serial data out (DIN)
// pin 5 - Data/Command select (D/C)
// pin 4 - LCD chip select (CS)
// pin 3 - LCD reset (RST)
Adafruit_PCD8544 display = Adafruit_PCD8544(7, 6, 5, 4, 3);
#define NUMFLAKES 10
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH  16
const static unsigned char PROGMEM logo16_glcd_bmp[] =
{ B00000000, B11000000,
  B00000001, B11000000,
  B00000011, B11100000,
  B11110011, B11100000,
  B11111110, B11111000,
  B01111110, B11111111,
  B00110011, B10011111,
  B00011111, B11111100,
  B00001101, B01110000,
  B00011011, B10100000,
  B00111111, B11100000,
  B00111111, B11110000,
  B01111100, B11110000,
  B01110000, B01110000,
  B00000000, B00110000 };
void setup()   {
  display.begin();
  // init done
  // you can change the contrast around to adapt the display
  // for the best viewing!
  display.setContrast(50);
  display.display(); // show splashscreen
  delay(2000);
  display.clearDisplay();   // clears the screen and buffer
  // draw a single pixel
  display.drawPixel(10, 10, BLACK);
  display.display();
  delay(2000);
  // draw many lines
  testdrawline();
  display.display();
  delay(2000);
  // draw rectangles
  testdrawrect();
  display.display();
  delay(2000);
  // draw multiple rectangles
  testfillrect();
  display.display();
  delay(2000);
  // draw mulitple circles
  testdrawcircle();
  display.display();
  delay(2000);
  // draw a circle, 10 pixel radius
  display.fillCircle(display.width()/2, display.height()/2, 10, BLACK);
  display.display();
  delay(2000);
  testdrawroundrect();
  delay(2000);
  testfillroundrect();
  delay(2000);
  testdrawtriangle();
  delay(2000);
  testfilltriangle();
  delay(2000);
  // draw the first ~12 characters in the font
  testdrawchar();
  display.display();
  delay(2000);
  // text display tests
  display.setTextSize(1);
  display.setTextColor(BLACK);
  display.setCursor(0,0);
  display.println("Hello, world!");
  display.setTextColor(WHITE, BLACK); // 'inverted' text
  display.println(3.141592);
  display.setTextSize(2);
  display.print("0x"); display.println(0xDEADBEEF, HEX);
  display.display();
  delay(2000);
  // miniature bitmap display
  display.drawBitmap(30, 16,  logo16_glcd_bmp, 16, 16, 1);
  display.display();
  // invert the display
  display.invertDisplay(true);
  display.invertDisplay(false);
  // draw a bitmap icon and 'animate' movement
  testdrawbitmap(logo16_glcd_bmp, LOGO16_GLCD_HEIGHT, LOGO16_GLCD_WIDTH);
void testdrawbitmap(const uint8_t *bitmap, uint8_t w, uint8_t h) {
  uint8_t icons[NUMFLAKES][3];
  srandom(666);     // whatever seed
  // initialize
  for (uint8_t f=0; f< NUMFLAKES; f++) {
    icons[f][XPOS] = random() % display.width();
    icons[f][YPOS] = 0;
    icons[f][DELTAY] = random() % 5 + 1;
    Serial.print("x: ");
    Serial.print(icons[f][XPOS], DEC);
    Serial.print(" y: ");
    Serial.print(icons[f][YPOS], DEC);
    Serial.print(" dy: ");
    Serial.println(icons[f][DELTAY], DEC);
  while (1) {
    // draw each icon
      display.drawBitmap(icons[f][XPOS], icons[f][YPOS], logo16_glcd_bmp, w, h, BLACK);
    display.display();
    delay(200);
    // then erase it + move it
      display.drawBitmap(icons[f][XPOS], icons[f][YPOS],  logo16_glcd_bmp, w, h, WHITE);
      // move it
      icons[f][YPOS] += icons[f][DELTAY];
      // if its gone, reinit
      if (icons[f][YPOS] > display.height()) {
   icons[f][YPOS] = 0;
void testdrawchar(void) {
  for (uint8_t i=0; i < 168; i++) {
    if (i == '\n') continue;
    display.write(i);
    //if ((i > 0) && (i % 14 == 0))
      //display.println();
  display.display();
[A lot of code]
I got the same error if i try to compile this.
void setup()   {
/usr/share/arduino/libraries/Robot_Control/keyboard.cpp: In member function ‘int8_t RobotControl::keyboardRead()’:
/usr/share/arduino/libraries/Robot_Control/keyboard.cpp:31: error: ‘KEY’ was not declared in this scope
Found the problem!
I just:
acer@Parrot:/usr/share/arduino/libraries/Robot_Control$ sudo mv Adafruit_GFX.cpp Adafruit_GFX.h /home/acer
[sudo] password for acer:
