Hello,
I'm having a strange occurrence with the messenger widget.
If I add a delay of 2 seconds I do get a message in the messenger widget and if I set it to 5 minutes I don't get it.
I have a button that I can use to turn on all 3 lights in my IoT Home Lights. Later that evening I use the same button to switch off the lights again with a delay of 5 minutes.
I do not understand. Is the delay in this the fault or am I doing something wrong.
Please help here.
Thanks.
Bert
The code
Sketch generated by the Arduino IoT Cloud Thing "Untitled"
https://create.arduino.cc/cloud/things/92d2541e-52f7-4066-ba52-4dabdc9e833c
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
String msg1;
int light_Value;
int offset_low;
int slider_Hour;
int slider_Minute;
bool alles;
bool automatisch;
bool boven_de_bank;
bool schommel_en_radio;
bool staande_lamp;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#include <Arduino_ConnectionHandler.h>
#include <RTClib.h>
#define LDR_PIN 36 // ESP32 pin GIOP36 (ADC0)
#define Staand 25 // Look at esp32 Board , and Look Pin diagram, Here We Using GPIO Number
#define Bank 33 // Look at esp32 Board , and Look Pin diagram, Here We Using GPIO Number
#define Radio 32 // Look at esp32 Board , and Look Pin diagram, Here We Using GPIO Number
int Hour, Min;
int flag1 = 0;
char str[5];
int analogValue;
int Slider_uur;
int Slider_minuut;
int Offset_low;
DateTime now;
RTC_DS3231 rtc;
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
pinMode(Staand, OUTPUT); // Staande lamp
pinMode(Bank, OUTPUT); // Boven de bank
pinMode(Radio, OUTPUT); // Schommelstoel & radio
digitalWrite(Staand, HIGH); // Relay OFF
digitalWrite(Bank, HIGH); // Relay OFF
digitalWrite(Radio, HIGH); // Relay OFF
if (! rtc.begin())
Serial.println(" RTC Module not Present");
while (1);
if (rtc.lostPower())
Serial.println("RTC power failure, reset the time!");
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
now = rtc.now();
Hour = (now.hour());
Min = (now.minute());
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
// Your code here
now = rtc.now();
light_Value = analogRead(LDR_PIN);
Testen_op_lampen_uit();
Since StaandeLamp is READ_WRITE variable, onStaandeLampChange() is
executed every time a new value is received from IoT Cloud.
void onStaandeLampChange() {
// Add your code here to act upon StaandeLamp change
if (staande_lamp) {
digitalWrite(Staand, LOW); // ON
msg1 = "Staande lamp is aan";
else {
digitalWrite(Staand, HIGH); // OFF
msg1 = "Staande lamp is uit";
Since BovenDeBank is READ_WRITE variable, onBovenDeBankChange() is
void onBovenDeBankChange() {
// Add your code here to act upon BovenDeBank change
if (boven_de_bank) {
digitalWrite(Bank, LOW); // ON
msg1 = "Boven de bank lamp aan";
else {
digitalWrite(Bank, HIGH); // OFF
msg1 = "Boven de bank lamp uit";
Since SchommelEnRadio is READ_WRITE variable, onSchommelEnRadioChange() is
void onSchommelEnRadioChange() {
// Add your code here to act upon SchommelEnRadio change
if (schommel_en_radio) {
digitalWrite(Radio, LOW); // ON
msg1 = "Schommel en radio lamp aan";
else {
digitalWrite(Radio, HIGH); // OFF
msg1 = "Schommel en radio lamp uit";
Since Alles is READ_WRITE variable, onAllesChange() is
void onAllesChange() {
// Add your code here to act upon Alles change
if (alles) {
digitalWrite(Staand, LOW); //Everything ON
msg1 = "Alles aan";
if(!alles) {
delay(300000); // Real life 5 minutes
//delay(2000); // For testing 2 seconds
digitalWrite(Staand, HIGH); // Everything OFF
msg1 = "Alles uit over 5 minuten";
Since Automatisch is READ_WRITE variable, onAutomatischChange() is
void onAutomatischChange() {
if (!automatisch) {
msg1 = "Automatisch verlichting is uitgeschakeld";
//Serial.print("Automatisch verlichting is uitgeschakeld ");
// Bepalen of de verlichting aan moet
if (automatisch && flag1 == 0) {
msg1 = "Automatisch verlichting is ingeschakeld. Wachten op schemering.";
Serial.print("Automatisch verlichting is ingeschakeld. Wachten op schemering.");
Since LightValue is READ_WRITE variable, onLightValueChange() is
void onLightValueChange() {
// Add your code here to act upon LightValue change
Since SliderHour is READ_WRITE variable, onSliderHourChange() is
void onSliderHourChange() {
// Add your code here to act upon SliderHour change
Slider_uur = slider_Hour;
Since SliderMinute is READ_WRITE variable, onSliderMinuteChange() is
void onSliderMinuteChange() {
// Add your code here to act upon SliderMinute change
Slider_minuut = slider_Minute;
// Rounded HH:mm format
char * hoursToString(double h, char *str)
int m = int(round(h * 60));
int hr = (m / 60) % 24;
int mn = m % 60;
str[0] = (hr / 10) % 10 + '0';
str[1] = (hr % 10) + '0';
str[2] = ':';
str[3] = (mn / 10) % 10 + '0';
str[4] = (mn % 10) + '0';
str[5] = '\0';
return str;
Since Msg1 is READ_WRITE variable, onMsg1Change() is
void onMsg1Change() {
// Add your code here to act upon Msg1 change
void Testen_op_lampen_uit(){
Serial.print("Lichtwaarde = "); Serial.println(light_Value); // the raw analog reading
if (light_Value < 1100) {
//Serial.println("Verlichting is aan, waarde lager dan 1100");
msg1 = "Automatische verlichting is aan";
msg1 = "flag1 1";
flag1 = 1;
delay(2000);
// Bepalen of de verlichting uit moet gaan
if (automatisch && now.hour() == Slider_uur && now.minute() == Slider_minuut && flag1 == 1) {
delay(2000);
msg1 = "Automatische verlichting is uit ";
flag1 = 2;
msg1 = "flag1 2";
// Bepalen wanneer het weer licht genoeg is om de volgende cycles te starten
if (automatisch && flag1 == 2) {
if (light_Value > 1400) {
flag1 = 0;
delay(2000);
msg1 = "flag1 3";
