In need of help combining two Ultrasonic Sensor codes together
Hi everyone!
I’m currently building a fountain that reacts to movement, to experiment with the ultrasonic sensor (HC-SR04) I tried a lot of different codes but every single one of them was giving me a constant output of 0. Then I stumbled upon this code and it read the distance correctly:
long reflectionDuration; // The time it takes to get the echo of the waves
long distanceInCm; // Calculated distance in centimeter
const int TRIGGER_PIN = 7; // The arduino pin connected to the trigger pin
const int ECHO_PIN = 6; // The arduino pin connected to the echo pin
pinMode(ECHO_PIN, INPUT); // We receive the results from the Echo, so it's input
pinMode(TRIGGER_PIN, OUTPUT); // We trigger the module to start sending waves, so it's output
Serial.begin(9600); // Initialize serial pin to fetch responses from Arduino Uno
digitalWrite(TRIGGER_PIN, HIGH); // Set the trigger pin to HIGH to start sending
delayMicroseconds(10); // Wait for 10 microseconds while sending is in progress
digitalWrite(TRIGGER_PIN, LOW); // Stop sending waves
// Duration from sending the signal until the sensor module receives the echo of the waves (in microseconds)
// check the pulseIn() function documentation for more info.
reflectionDuration = pulseIn(ECHO_PIN, HIGH);
// The time takes for the signal to goes and gets reflected should be divided by 2 to
// get the time it takes for the ultrasonic wave to go from the module to the reflection point
// then divide it by 29.1 to calculate the distance in centimeter
distanceInCm = (reflectionDuration/2) / 29.1;
Serial.println(distanceInCm);
delay(250);
Source
But now I need to combine this with my project, and I’m very new to this so I need your help. I did this lesson in Tinkercad and I want to use this code and setup to power my motors. I know how it will work with motors and transistors but i want to test it with simple LED’s first. Below is the image and code:
Arduino setup
int distanceThreshold = 0;
int cm = 0;
int inches = 0;
long readUltrasonicDistance(int triggerPin, int echoPin)
pinMode(triggerPin, OUTPUT); // Clear the trigger
digitalWrite(triggerPin, LOW);
delayMicroseconds(2);
// Sets the trigger pin to HIGH state for 10 microseconds
digitalWrite(triggerPin, HIGH);
pinMode(echoPin, INPUT);
// Reads the echo pin, and returns the sound wave travel time in microseconds
return pulseIn(echoPin, HIGH);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
// set threshold distance to activate LEDs
distanceThreshold = 350;
// measure the ping time in cm
cm = 0.01723 * readUltrasonicDistance(7, 6);
// convert to inches by dividing by 2.54
inches = (cm / 2.54);
Serial.print(cm);
Serial.print("cm, ");
Serial.print(inches);
Serial.println("in");
if (cm > distanceThreshold) {
digitalWrite(2, LOW);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
if (cm <= distanceThreshold && cm > distanceThreshold - 100) {
digitalWrite(2, HIGH);
if (cm <= distanceThreshold - 100 && cm > distanceThreshold - 250) {
digitalWrite(3, HIGH);
if (cm <= distanceThreshold - 250 && cm > distanceThreshold - 350) {
digitalWrite(4, HIGH);
if (cm <= distanceThreshold - 350) {
delay(100); // Wait for 100 millisecond(s)
It will turn on the LED’s on and off depending on the distance of the object to the ultrasonic distance sensor. But it still reads the value as 0cm and 0in, so how do I combine the two codes so that I get the right readout?
I think the first thing you need to do is grab a ruler or a tape measure. Is it marked in inches or centimeters?
There is no reason for cm and inches to be global when you only use the variables in loop().
That is NOT what that code does.
One code (that works) sets the mode of the trigger and echo pins once. One code (that doesn't work) sets the mode of the trigger and echo pins over and over.
I don't know about you, but I'd go with the approach that works.
One code (that works) sets the trigger pin HIGH once and LOW once. One code (that doesn't work) sets the trigger pin HIGH twice and LOW twice.
Code tags are a wonderful thing. Too bad you failed to use them.
Thank you for the quick response and damn I totally missed the code tags, I feel so stupid having missed it xD
I know what you mean and I have to go with what works, but the function of the lower code (reading out the distance and setting another pin (which will be an LED) to high is what I need, but my sensor is not working with that code, but it IS working with the top code. So I need to merge the first one into the second one so that the second one will work.
Are you waiting for permission?
I just don't know how i merge them together? Where should what parts of the code go?
You don't need to merge anything. You have a function that works, in one code, and a function that doesn't work in another code. Delete the function that doesn't work and copy the one that does.
I've already pointed out the differences between the working and the non-working versions.
