In side ARDUINO Library
Dear All
pinMode(2,OUTPUT);
After executing above code pin 2 of Arduino becomes output
But it is actually
DDRD |= 1<< 2; // Data direction register
My Question is
Can we see the in side the ARDUINO library, above second code
Please advice
Thanks i advance
Yes, you have the source code, you are positively encouraged to go and read it. Quite where it is
depends on which OS and Arduino version, but in something like .../hardware/arduino/avr/cores/arduino/
or .../hardware/arduino/cores/arduino/ inside your install.
PS There's more to pinMode than that, its interrupt-safe for one thing.
Here’s the code for AVR in 1.0.5
void pinMode(uint8_t pin, uint8_t mode)
	uint8_t bit = digitalPinToBitMask(pin);
	uint8_t port = digitalPinToPort(pin);
	volatile uint8_t *reg, *out;
	if (port == NOT_A_PIN) return;
	// JWS: can I let the optimizer do this?
	reg = portModeRegister(port);
	out = portOutputRegister(port);
	if (mode == INPUT) {
		uint8_t oldSREG = SREG;
                cli();
		*reg &= ~bit;
		*out &= ~bit;
		SREG = oldSREG;
	} else if (mode == INPUT_PULLUP) {
                cli();
		*reg &= ~bit;
		*out |= bit;
		SREG = oldSREG;
                cli();
		*reg |= bit;
		SREG = oldSREG;
You need to hunt around for some of the machinery it uses, …/…/variants/standard/pins_arduino.h for
instance.
MarkT:
Here's the code for AVR in 1.0.5
cli();
*reg &= ~bit;
*out &= ~bit;
SREG = oldSREG;
                cli();
*reg &= ~bit;
*out |= bit;
SREG = oldSREG;
                cli();
*reg |= bit;
SREG = oldSREG;
You need to hunt around for some of the machinery it uses, ../../variants/standard/pins_arduino.h for
instance.
Thanks for the reply
Please advice to find this file in arduino library
MarkT:
depends on which OS and Arduino version, but in something like …/hardware/arduino/avr/cores/arduino/
or …/hardware/arduino/cores/arduino/ inside your install.
PS There’s more to pinMode than that, its interrupt-safe for one thing.
Dear Mark Thanks for the reply
I searched H files but I did not fine it
Use grep (Linux/Mac) or grepWin (Windows). The source is in wiring_digital.c (IDE 1.6.6)
