INA169 ANALOG DC CURRENT SENSOR
Hello,
Please, I have a problem of current measurement by current sensor '' INA169 Analog DC Current Sensor '': http://www.maplin.co.uk/p/adafruit-ina169-analog-dc-current-sensor-breakout-60v-5a-max-n47dq. I use the arduino program:
// Constants
const int SENSOR_PIN = A0; // Input pin for measuring Vout
const int RS = 10; // Shunt resistor value (in ohms)
const int VOLTAGE_REF = 5; // Reference voltage for analog read
// Global Variables
float sensorValue; // Variable to store value from analog read
float current; // Calculated current value
// Initialize serial monitor
// Read a value from the INA169 board
sensorValue = analogRead(SENSOR_PIN);
// Remap the ADC value into a voltage number (5V reference)
sensorValue = (sensorValue * VOLTAGE_REF) / 1023;
// Follow the equation given by the INA169 datasheet to
// determine the current flowing through RS. Assume RL = 10k
// Is = (Vout x 1k) / (RS x RL)
current = sensorValue / (10 * RS);
// Output value (in amps) to the serial monitor to 3 decimal
// places
Serial.print(current, 3);
Serial.println(" A");
// Delay program for a few milliseconds
But, our sensor always indicates zero. I think that the problem is in the arduino program above, this program is that of another sensor: INA169 Breakout Board Hookup Guide - SparkFun Learn
could you please help me to solve this problem,
thank you in advance!!
You probably wired it wrong, but I can't say for sure since you gave no details or pictures as to how you wired your project :frowning: .
