INA219 Current Sensor and L298N Motor Driver Help
Hi all I am currently conducting a project utilising a L298N Motor Driver to control two motors independently. I wish to connect an Adafruit INA219 current sensor to read current drawn from Motor 1 and at certain conditions such as if Motor 1 is receiving no current to initiate the spin of Motor 2.
I exclusively power the Motor Driver (logic side as well) using a 12V external power supply. I have then connected my INA219 to the Arduino 5V supply and have grounded all components on the same rail. When reading current I am receiving extremely volatile readings spiking from 0 to 500ma and so on.
From my description could anyone inform me on what I'm doing wrong or how I should approach this better?
Thanks in advance.
#include <Wire.h>
#include <Adafruit_INA219.h>
Adafruit_INA219 ina219;
//L293D
//Motor A
const int motorPin1  = 9;  // IN4 of L293
const int motorPin2  = 10;  // IN3 of L293
//Motor B
const int motorPin3  = 6; // IN2 of L293
const int motorPin4  = 5;  // IN1 of L293
//This will run only one time.
void setup(void){
    //Set pins as outputs
    //pinMode(motorPin1, OUTPUT);
    //pinMode(motorPin2, OUTPUT);
    //pinMode(motorPin3, OUTPUT);
    //pinMode(motorPin4, OUTPUT);
    //Motor Control - Motor A: motorPin1,motorpin2 & Motor B: motorpin3,motorpin4
    //This code  will turn Motor A clockwise for 2 sec.
    //delay(5000);
    /*This code will turn Motor A counter-clockwise for 2 sec.
    analogWrite(motorPin1, 0);
    analogWrite(motorPin2, 180);
    analogWrite(motorPin3, 0);
    analogWrite(motorPin4, 180);
    delay(5000);
    //This code will turn Motor B clockwise for 2 sec.
    analogWrite(motorPin3, 180);
    analogWrite(motorPin4, 0);
    //This code will turn Motor B counter-clockwise for 2 sec.
    analogWrite(motorPin1, 180);
    analogWrite(motorPin2, 0);
    //And this code will stop motors
    analogWrite(motorPin4, 0); */
    {Serial.begin(115200);
while (!Serial) {
      // will pause Zero, Leonardo, etc until serial console opens
      delay(1);
uint32_t currentFrequency;
ina219.begin();
void loop(){
float shuntvoltage = 0;
float busvoltage = 0;
float current_mA = 0;
float loadvoltage = 0;
float power_mW = 0;
  shuntvoltage = ina219.getShuntVoltage_mV();
  busvoltage = ina219.getBusVoltage_V();
  current_mA = ina219.getCurrent_mA();
  power_mW = ina219.getPower_mW();
  loadvoltage = busvoltage + (shuntvoltage / 1000);
  Serial.println("");
  Serial.print("Bus Voltage:   "); Serial.print(busvoltage); Serial.println(" V");
  Serial.print("Shunt Voltage: "); Serial.print(shuntvoltage); Serial.println(" mV");
  Serial.print("Load Voltage:  "); Serial.print(loadvoltage); Serial.println(" V");
  Serial.print("Current:       "); Serial.print(current_mA); Serial.println(" mA");
  Serial.print("Power:         "); Serial.print(power_mW); Serial.println(" mW");
  Serial.println("");
if (current_mA > 10 || current_mA < -10)
  {analogWrite(motorPin1, 100);
  delay(1000);}
if (-10 <current_mA < 10){
    Serial.print("CONSTANT SIGNAL FAULT");
    Serial.println("");
    analogWrite(motorPin2, 100);
    analogWrite(motorPin3, 100);
delay(1000);}
if (current_mA>150)
  {Serial.print("MAX CURRENT WARNING");
  Serial.println("");
  delay(1000);}
KYOKYO:
The most obvious thing is that you're not sharing your schematic. We will need to see that to be able to help at all.
KYOKYO:
It is the nature of analogWrite() that what actually happens is that the output is being switched on and off rapidly, right? And the sampling speed of the INA219 is much faster (500,000 times/sec) than the default PWM frequency on the analogWrite(). You could be getting totally accurate data, just at such a fine-grained level it does not get you what you're looking for.
I don't know what filtering the adafruit board has on it, but you may need to add some capacitance to the filter. The INA219 datasheet has some suggestions about filtering.
