Inaccuracy of delayMicroseconds()
I have a timing-critical application, and I’m trying to use delayMicroseconds to control a pulse width. It works wonderfully at higher values, but at ~10 it’s off by a number of clock cycles.
#define STROBE_PORT PORTE
const int strobePin = 4;
unsigned int strobeTime = 10;
pinMode(2, OUTPUT);
digitalWrite(2, LOW);
if ( correctSerialInput )
powerPulse();
void powerPulse()
  if ( strobeTime <= 10000 )
  cli();
  sbi(STROBE_PORT, strobePin);
  delayMicroseconds(strobetime);
  cbi(STROBE_PORT, strobePin);
  sei();
Pulse width: 9.675us
The critical code is everything between sbi() and cbi(), as that controls the width of the pulse. So I thought I’d take a look at the assembly code:
  36:      74 9a             sbi      0x0e, 4      ; 14
  38:      c9 01             movw      r24, r18
  3a:      0e 94 00 00       call      0      ; 0x0 <_Z10powerPulsev>
                  3a: R_AVR_CALL      delayMicroseconds
  3e:      74 98             cbi      0x0e, 4      ; 14
There’s a movw and a call: 1 + 5 = 6. Now, taking a look at the function-
delayMicroseconds:
#if F_CPU >= 16000000L
      // for the 16 MHz clock on most Arduino boards
      // for a one-microsecond delay, simply return.  the overhead
      // of the function call yields a delay of approximately 1 1/8 us.
      if (--us == 0)
   0:      01 97             sbiw      r24, 0x01      ; 1
   2:      01 f0             breq      .+0            ; 0x4 <delayMicroseconds+0x4>
                  2: R_AVR_7_PCREL      .text.delayMicroseconds+0x12
            return;
      // the following loop takes a quarter of a microsecond (4 cycles)
      // per iteration, so execute it four times for each microsecond of
      // delay requested.
      us <<= 2;
   4:      88 0f             add      r24, r24
   6:      99 1f             adc      r25, r25
   8:      88 0f             add      r24, r24
   a:      99 1f             adc      r25, r25
      // account for the time taken in the preceeding commands.
      us -= 2;
   c:      02 97             sbiw      r24, 0x02      ; 2
      // we can't subtract any more than this or we'd overflow w/ small delays.
      us--;
#endif
      // busy wait
      __asm__ __volatile__ (
   e:      01 97             sbiw      r24, 0x01      ; 1
  10:      01 f4             brne      .+0            ; 0x12 <delayMicroseconds+0x12>
                  10: R_AVR_7_PCREL      .text.delayMicroseconds+0xe
  12:      08 95             ret
Instruction - cycles
sbiw - 2
breq - 1 (condition is false)
add - 1
adc - 1
add - 1
adc - 1
sbiw - 2
(the us–; is from a different #ifdef branch and isn’t actually compiled)
Once in the loop it starts subtracting from the us variable, but its changed since it was passed:
r25/r24 = 10
sbiw 1 → 9
us <<= 2 → 36
sbiw 2 → 34
For us = 34 to us = 2, sbiw takes 2 clock cycles, brne takes 2 (condition true).
33*4 = 132
In the last loop, us reaches 0, so brne only takes 1 cycle, plus a return: 2+1+5 = 8.
Summing up the cycles in delayMicroseconds: 9 + 132 + 8 = 149.
Add 6 from before: 155 clock cycles.
155/16 = 9.6875us which is approximately what I’m seeing.
Adding up all of the clock cycles involved with the function, you get:
5 + 9 + 4( 4(us-1) - 2 - 1 ) + 3 + 5
Simplifying yields: 16us - 6. This is an error of 6 clock cycles or 0.375us. At 10us, this is a -3.75% error which is too high for my application, and quite possibly for others.
A simple solution would be as follows:
Replace the “us -= 2;” with “us -= 1;”. This would reduce the error to -2 clock cycles, which could be remedied by adding 2 nop’s.
It might be wise to just indicate the 6 cycle error in the reference. There is still some overhead in setting up the function, and that can vary. Reducing the error to 0 means the setup overhead will cause an unavoidable positive error. If a user knows about the error, it would be easy to compensate by figuring out your setup overhead, and adding nop’s to bring it to 6 cycles.
a difference of exactly 5 cycles. What gives?
Call/return overhead?
Just a guess.
Still working out the math. Hold on :P
Alright, the math is worked out. There's an inherent error of 6 clock cycles in the function which could easily be solved.
