Inaccurate Flex Sensor Readings for Bad Posture Detection at Lumbar Spine
Hello, I'm working on a project to detect bad posture using a flex sensor positioned at the lumbar spine. However, I'm struggling with inaccurate angle readings despite thorough code and circuit checks.
Here's a snippet of my code:
const int flexPin = A0; // Flex sensor input pin
const int threshold = 100; // Threshold for detecting bad posture
Serial.begin(9600); // Initialize serial communication
int flexValue = analogRead(flexPin); // Read flex sensor value
float angle = map(flexValue, 0, 1023, 0, 180); // Map flex sensor value to angle range (adjust as needed)
if (angle > threshold) {
// Bad posture detected
Serial.println("Bad posture detected!");
// Add code for alerting user (e.g., activating a buzzer)
delay(100); // Delay for stability (adjust as needed)
I'm uncertain if there's incorrect or missing code contributing to the issue. I'd appreciate any guidance or suggestions on improving accuracy, especially considering the lumbar spine placement. My goal is precise angle detection for effective posture monitoring.
Your assistance would be invaluable. Thank you for your time.
Which flex sensor? Post a datasheet.
Show your circuit.
What range of angles are you expecting?
How accurate do you expect the sensor to be?
How are you testing the sensor?
How are you attaching it to a person?
Did you notice that comment in the code? Try calibrating the sensor by measuring the output with known flex angles, and "adjust as needed".
