I am currently using the Arduino Due, a Macbook pro, and have purchased a BLE shield from Red Bear labs (http://redbearlab.com/bleshield/)
I have installed their libraries, however I am having problems running their example projects. The Arduino IDE says that <avr/sleep.h> could not be found:
In file included from BLEControllerSketch.ino:16:0:
/Users/shazkam/Documents/Arduino/libraries/RBL_nRF8001/RBL_nRF8001.h:21:23: fatal error: avr/sleep.h: No such file or directory
#include <avr/sleep.h>
compilation terminated.
However, the avr library and the sleep.h file are included with the arduino software as can be seen from my screen shot: http://i.imgur.com/tecWrNA.png
Most of the example code that I am trying to run can be found below (I could not put all of it as characters here are limited)
#include <Servo.h>
#include <SPI.h>
#include <boards.h>
#include <RBL_nRF8001.h>
#include <services.h>
#include "Boards.h"
#define PROTOCOL_MAJOR_VERSION 0 //
#define PROTOCOL_MINOR_VERSION 0 //
#define PROTOCOL_BUGFIX_VERSION 2 // bugfix
#define PIN_CAPABILITY_NONE 0x00
#define PIN_CAPABILITY_DIGITAL 0x01
#define PIN_CAPABILITY_ANALOG 0x02
#define PIN_CAPABILITY_PWM 0x04
#define PIN_CAPABILITY_SERVO 0x08
#define PIN_CAPABILITY_I2C 0x10
// pin modes
//#define INPUT 0x00 // defined in wiring.h
//#define OUTPUT 0x01 // defined in wiring.h
#define ANALOG 0x02 // analog pin in analogInput mode
#define PWM 0x03 // digital pin in PWM output mode
#define SERVO 0x04 // digital pin in Servo output mode
byte pin_mode[TOTAL_PINS];
byte pin_state[TOTAL_PINS];
byte pin_pwm[TOTAL_PINS];
byte pin_servo[TOTAL_PINS];
Servo servos[MAX_SERVOS];
Serial.begin(57600);
Serial.println("BLE Arduino Slave");
/* Default all to digital input */
for (int pin = 0; pin < TOTAL_PINS; pin++)
// Set pin to input with internal pull up
pinMode(pin, INPUT);
digitalWrite(pin, HIGH);
// Save pin mode and state
pin_mode[pin] = INPUT;
pin_state[pin] = LOW;
// Default pins set to 9 and 8 for REQN and RDYN
// Set your REQN and RDYN here before ble_begin() if you need
//ble_set_pins(3, 2);
// Set your BLE Shield name here, max. length 10
//ble_set_name("My Name");
// Init. and start BLE library.
ble_begin();
static byte buf_len = 0;
byte reportPinAnalogData()
if (!ble_connected())
return 0;
static byte pin = 0;
byte report = 0;
if (!IS_PIN_DIGITAL(pin))
pin++;
if (pin >= TOTAL_PINS)
pin = 0;
return 0;
if (pin_mode[pin] == ANALOG)
uint16_t value = analogRead(pin);
byte value_lo = value;
byte value_hi = value>>8;
byte mode = pin_mode[pin];
mode = (value_hi << 4) | mode;
byte buf[] = {'G', pin, mode, value_lo};
ble_write_string(buf, 4);
pin++;
pin = 0;
return report;
byte queryDone = false;
while(ble_available())
byte cmd;
cmd = ble_read();
Serial.write(cmd);
// Parse data here
switch (cmd)
case 'V': // query protocol version
byte buf[] = {'V', 0x00, 0x00, 0x01};
case 'C': // query board total pin count
byte buf[2];
buf[0] = 'C';
buf[1] = TOTAL_PINS;
ble_write_string(buf, 2);
case 'M': // query pin mode
byte pin = ble_read();
byte buf[] = {'M', pin, pin_mode[pin]}; // report pin mode
ble_write_string(buf, 3);
case 'S': // set pin mode
byte mode = ble_read();
if (IS_PIN_SERVO(pin) && mode != SERVO && servos[PIN_TO_SERVO(pin)].attached())
servos[PIN_TO_SERVO(pin)].detach();
/* ToDo: check the mode is in its capability or not */
/* assume always ok */
if (mode != pin_mode[pin])
pinMode(pin, mode);
pin_mode[pin] = mode;
if (mode == OUTPUT)
digitalWrite(pin, LOW);
else if (mode == INPUT)
pin_state[pin] = HIGH;
else if (mode == ANALOG)
if (IS_PIN_ANALOG(pin)) {
if (IS_PIN_DIGITAL(pin)) {
pinMode(PIN_TO_DIGITAL(pin), LOW);
else if (mode == PWM)
if (IS_PIN_PWM(pin))
pinMode(PIN_TO_PWM(pin), OUTPUT);
analogWrite(PIN_TO_PWM(pin), 0);
pin_pwm[pin] = 0;
pin_mode[pin] = PWM;
else if (mode == SERVO)
if (IS_PIN_SERVO(pin))
pin_servo[pin] = 0;
pin_mode[pin] = SERVO;
if (!servos[PIN_TO_SERVO(pin)].attached())
servos[PIN_TO_SERVO(pin)].attach(PIN_TO_DIGITAL(pin));
// reportPinAnalogData(pin);
if ( (mode == INPUT) || (mode == OUTPUT) )
reportPinDigitalData(pin);
reportPinPWMData(pin);
reportPinServoData(pin);
case 'A': // query all pin status
reportPinCapability(pin);
if ( (pin_mode[pin] == INPUT) || (pin_mode[pin] == OUTPUT) )
else if (pin_mode[pin] == PWM)
else if (pin_mode[pin] == SERVO)
queryDone = true;
uint8_t str[] = "ABC";
sendCustomData(str, 3);
case 'P':
case 'Z':
byte len = ble_read();
byte buf[len];
for (int i=0;i<len;i++)
buf[i] = ble_read();
Serial.println("->");
Serial.print("Received: ");
Serial.print(len);
Serial.println(" byte(s)");
Serial.print(" Hex: ");
Serial.print(buf[i], HEX);
// send out any outstanding data
ble_do_events();
buf_len = 0;
return; // only do this task in this loop
if (Serial.available())
byte d = 'Z';
ble_write(d);
delay(5);
while(Serial.available())
d = Serial.read();
ble_write(d);
ble_do_events();
buf_len = 0;
return;
// No input data, no commands, process analog data
queryDone = false; // reset query state
if (queryDone) // only report data after the query state
byte input_data_pending = reportDigitalInput();
if (input_data_pending)
ble_do_events();
buf_len = 0;
reportPinAnalogData();
ble_do_events();
buf_len = 0;
return;
ble_do_events();
buf_len = 0;
The file that is throwing the error is:
#ifndef _RBL_NRF8001_H
#define _RBL_NRF8001_H
#include <boards.h>
#include <lib_aci.h>
#include <aci_setup.h>
#include <SPI.h>
#include <avr/interrupt.h>
/* Put the nRF8001 setup in the RAM of the nRF8001.*/
#include "RBL_services.h"
/* Include the services_lock.h to put the setup in the OTP memory of the nRF8001.
This would mean that the setup cannot be changed once put in.
However this removes the need to do the setup of the nRF8001 on every reset.*/
#if defined(BLEND_MICRO)
#define DEFAULT_REQN 6
#define DEFAULT_RDYN 7
#else
#define DEFAULT_REQN 9
#define DEFAULT_RDYN 8
#endif
void ble_begin();
void ble_set_name(char *name);
void ble_write(unsigned char data);
void ble_write_bytes(unsigned char *data, unsigned char len);
void ble_do_events();
int ble_read();
unsigned char ble_available();
unsigned char ble_connected(void);
void ble_set_pins(uint8_t reqn, uint8_t rdyn);
unsigned char ble_busy();
#endif
I cannot seem to enable the compiler to the include the sleep.h file which is inside the Arduino app. Any help on this would be greatly appreciated.
