#include <Ethernet.h>
I need to send two data to my database generated by the arduino, but one is sent, how can I send both data?
#include <SPI.h>
#include <SDS011.h>
// Configuracion del Ethernet Shield
byte mac = {0xDE, 0xAD, 0xBE, 0xEF, 0xFF, 0xEE}; // Direccion MAC
byte ip = { 192,168,1,101 }; // Direccion IP del Arduino
byte server = { 192,168,1,42 }; // Direccion IP del servidor
EthernetClient client;
float p10,p25;
int error;
static const uint8_t D0 = 16;
static const uint8_t D1 = 5;
static const uint8_t D2 = 6;
static const uint8_t D3 = 0;
static const uint8_t D4 = 2;
static const uint8_t D5 = 14;
static const uint8_t D6 = 12;
static const uint8_t D7 = 13;
static const uint8_t D8 = 15;
static const uint8_t RX = 3;
static const uint8_t TX = 1;
SDS011 my_sds;
void setup(void) {
Ethernet.begin(mac, ip); // Inicializamos el Ethernet Shield
delay(1000); // Esperamos 1 segundo de cortesia
Serial.println(“PM10 count,PM2.5 count,PM10 conc,PM2.5 conc”);
my_sds.begin(D1,D2);
void loop(void) {
error = my_sds.read(&p25,&p10);
if (! error) {
Serial.println("P2.5: "+String(p25));
Serial.println("P10: "+String(p10));
// Proceso de envio de muestras al servidor
Serial.println(“Connecting…”);
if (client.connect(server, 80)>0) { // Conexion con el servidor
client.print(“GET /sds011/lecturas.php?id=4&valor=”); // Enviamos los datos por GET
client.print(String(p25));
client.print(“GET /sds011/lecturas.php?valor2=”);
client.print(String(p10));
client.println(" HTTP/1.0");
client.println(“User-Agent: Arduino 1.0”);
client.println();
Serial.println(“Conectado”);
else {
Serial.println(“Fallo en la conexion”);
if (!client.connected()) {
Serial.println(“Disconnected!”);
client.stop();
client.flush();
delay(10000);
I use the following to send multiple data points in one GET request:
if (client.connect(“192.168.1.100”,pppp)) { // pppp = port number
client.print( “GET /datalogger/datalogger.php?data1=”); //Roof Temp
client.print( sensorValue[0]);
client.print( “&&data2=”); //Inside Temp
client.print( sensorValue[1]);
client.print( “&&data3=”); //Spare Temp
client.print( sensorValue[2]);
client.print( “&&data4=”); //Outside Temp
client.print( sensorValue[3]);
client.print( “&&data5=”); //Light Level
client.print( sensorValue[lightsensor]);
client.print( “&&data6=”); //Wind Speed 10m avg
client.print( sensorValue[wSpeed10]);
client.print( “&&data7=”); //Wind Gust
client.print( sensorValue[gust10]);
client.print( “&&data8=”); //Wind direction 10m avg
client.println( sensorValue[wDir10]);
client.println(“serverserver”);
client.println( “Connection: close” );
client.println();
client.println();
client.stop();
