include files no being found
I'm new to this programming , have used the default examples fine. but have tried to added an lcd program folder to the sketchbook directory. i can get to the folder using open under sketchbook and can load the pde. but when i try to upload it to the board it states .
21: error: LCD4x20.h: No such file or directory In function 'void setup()': In function 'void loop()':
i'm using windows xp
sgd58 :-[
The file LCD4x20.h does not come with the Arduino IDE. It's very likely part of a library but I don't know which one. Hopefully, someone who knows about the file will help.
Once you determine which library contains the file, you will have to download the library and install it. Typically, libraries have installation instructions.
  • Brian
