include <foo.h> in cpp file
Dear all
I created an Arduino *.INO sketch that includes some *.cpp file (tabs). In one of these tabs I want to include a header file from a downloaded library, let’s name it foo
so the first line in the CPP file is
#include <foo.h>
And when compiling this gives errors : file not found,
The *.H and *.cpp file are stored in "c:\user\XXX\My documents\Arduino\libraries\foo
It is possible to include the header file from the menu in the IDE, sketch, import library.
It is also possible to include the header file in the *.INI file, no problems arise
Examples given by the library are also compiled without error’s
what’s wrong ?
JanMenssen:
Dear all
#include <foo.h>
what’s wrong ?
#include "foo.h"
include "foo.h " doesn't work, means foo.h is not in library but in current sketch as far as I know
You refer to *.H files; if they have a capital H, you need to include with a capital H
#include <foo.H>
Not sure if it’s the issue but it caught my eye.
probably just a typo in your post, but is the file named foo.H or foo.h ?
Did you stop/start the IDE after putting the files in place ?
