Hello,
My project consists to create an Raspberry package (cores, variants, libraries...) for Arduino IDE. I just started this, and I created «pinMode(int, int)», «digitalWrite(int pin, int val)» and «digitalRead(int pin)» functions, but when I try to compile this in the Arduino IDE, the editor returned this error:
/home/faf/.arduino15/packages/industrialshields/tools/arm-gnueabihf-gcc/10.2-2020.11/bin/../lib/gcc/arm-none-linux-gnueabihf/10.2.1/../../../../arm-none-linux-gnueabihf/bin/ld: /tmp/arduino_build_166344/sketch/sketch_jan20a.ino.cpp.o: in function `setup()':
/home/faf/Projects/arduino-boards/arch/armgnueabihf/Tests/sketch_jan20a/sketch_jan20a.ino:3: undefined reference to `pinMode(int, int)'
collect2: error: ld returned 1 exit status
exit status 1
Error al compilar per a la placa Raspberry Pi.
My function are initialized correctly in Arduino.h:
#ifndef __ARDUINO_H__
#define __ARDUINO_H__
void pinMode(int, int);
void digitalWrite(int, int);
int digitalRead(int);
void setup(void);
void loop(void);
#endif
And if I try to compile this functions normally with gcc and it compile correctly. Any idea about I how can solve this issue.
