Hello everybody,
currently I'm testing the PushSafer-Service.
This is a service you have to pay for per notification and allows to send push-notifications to smartphones, browsers etc..
I want to use PushSafer at a place where on WLAN/WiFi only surfing with browsers is possible
Sending Emails with Email-Clients like Thunderbird etc. is blocked. I guess because the ports used for emails are closed.
The demo-code is pretty short.
Connect to WiFi
create client
setup event-details
call pushsafer.sendEvent()
#include <WiFi.h>
/*#include <WiFiClientSecure.h>*/
#include <WiFiClient.h>
#include <Pushsafer.h>
// Initialize Wifi connection to the router
char ssid[] = ""; // your network SSID (name)
char password[] = ""; // your network key
// Pushsafer private or alias key
#define PushsaferKey ""
/*WiFiClientSecure client;*/
WiFiClient client;
Pushsafer pushsafer(PushsaferKey, client);
Serial.println("Setup-Start");
// Set WiFi to station mode and disconnect from an AP if it was Previously
// connected
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
// Attempt to connect to Wifi network:
Serial.print("Connecting Wifi: ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.print("IP address: ");
pushsafer.debug = true;
// Take a look at the Pushsafer.com API at
// https://www.pushsafer.com/en/pushapi
struct PushSaferInput input;
input.message = "I'm the test message";
input.title = "Hello!";
input.sound = "8";
input.vibration = "1";
input.icon = "1";
input.iconcolor = "#FFCCCC";
input.priority = "1";
input.device = "a";
input.url = "https://www.pushsafer.com";
input.urlTitle = "Open Pushsafer.com";
input.picture = "";
input.picture2 = "";
input.picture3 = "";
input.time2live = "";
input.retry = "";
input.expire = "";
input.answer = "";
Serial.println(pushsafer.sendEvent(input));
Serial.println("Sent");
// client.stop();
I started looking into the source-code of the PushSafer-library
Even the PushSafer-library is pretty short
I guess the main thing about sending the data to pushsafer.com are these lines
client->print("POST /api"); client->println(" HTTP/1.1");
// Host header
client->print("Host: "); client->println(HOST);
client->println("User-Agent: arduino/1.0");
client->println("Accept: */*");
int contentLength = start_request.length() + end_request.length();
if (debug) Serial.println("Content-Length: " + String(contentLength));
client->print("Content-Length: "); client->println(String(contentLength));
client->println("Content-Type: multipart/form-data; boundary=" + boundary);
client->println("");
client->print(start_request);
if (debug) Serial.print(start_request);
client->print(end_request);
if (debug) Serial.print(end_request);
now=millis();
bool finishedHeaders = false;
bool currentLineIsBlank = true;
while (millis()-now<5000) {
while (client->available()) {
if (debug) Serial.println("response");
char c = client->read();
responseReceived=true;
So my question is:
As at the place I want to use an ESP32 with PushSafer only allows browsing (I guess http/https on port 80 and port 8080) and nothing else
Does this kind of sending data to PushSafer work the same way as browsing
= will work in a WiFi-WLAN where only browsing is possible?
I am very thankful for any kind of tips or hints how to determine what kind of "sending data"
protocol (HTTP, FTP, TCP, UDP) , method "POST" or "GET" or whatever and ports are used by PushSafer.
best regards Stefan
