Which version of the Arduino IDE are you using?
Are you compiling for the Mega 2560?
By "do not work", do you mean there is an error when you try to compile the sketch?
marijn:
can I put this in a platform.local.txt?
Yes.
marijn:
And where should I put that file?
In the same folder as the platform.txt file. Note that you'll need to redo this every time you update to a new version of the hardware package. Also note that the copy of the Arduino AVR Boards package that is located under the Arduino IDE installation folder will no longer be in use after you update Arduino AVR Boards via Boards Manager, so make sure you are putting your platform.local.txt in the right place.
marijn:
Is there an other solution to this problem?
I don't have much experience with using precompiled libraries, but I have managed to get it working fine without any goofy workarounds like what you resorted to. I'm happy to investigate this, but I don't own a BME680. So if it's a matter of "do not work" meaning that it won't compile, I can look into it, but if it's a matter of the sketch compiling but not working as expected then I'm more limited.
Ok when I revert to the platform.txt Bosch sugest and I compile basic.ino this is the result(removed first part to comply with the 9000 chars rule):
Linking everything together...
/Users/marijn/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections,--relax -mmcu=atmega2560 {compiler.c.elf.extra_flags} -o /var/folders/fh/rsttw1f90zq8_hcbqp16jlw40000gn/T/arduino_build_27338/basic.ino.elf /var/folders/fh/rsttw1f90zq8_hcbqp16jlw40000gn/T/arduino_build_27338/sketch/basic.ino.cpp.o /var/folders/fh/rsttw1f90zq8_hcbqp16jlw40000gn/T/arduino_build_27338/libraries/BSEC_Software_Library/bsec.cpp.o /var/folders/fh/rsttw1f90zq8_hcbqp16jlw40000gn/T/arduino_build_27338/libraries/BSEC_Software_Library/bme680/bme680.c.o /var/folders/fh/rsttw1f90zq8_hcbqp16jlw40000gn/T/arduino_build_27338/libraries/Wire/Wire.cpp.o /var/folders/fh/rsttw1f90zq8_hcbqp16jlw40000gn/T/arduino_build_27338/libraries/Wire/utility/twi.c.o /var/folders/fh/rsttw1f90zq8_hcbqp16jlw40000gn/T/arduino_build_27338/libraries/SPI/SPI.cpp.o /var/folders/fh/rsttw1f90zq8_hcbqp16jlw40000gn/T/arduino_build_27338/../arduino_cache_816138/core/core_arduino_avr_mega_cpu_atmega2560_354614c5233f58b3a5744826db5a4bbd.a -L/var/folders/fh/rsttw1f90zq8_hcbqp16jlw40000gn/T/arduino_build_27338 -lm
avr-gcc: error: {compiler.c.elf.extra_flags}: No such file or directory
Multiple libraries were found for "bsec.h"
Used: /Users/marijn/Documents/Arduino/libraries/BSEC_Software_Library
Multiple libraries were found for "Wire.h"
Used: /Users/marijn/Library/Arduino15/packages/arduino/hardware/avr/1.8.2/libraries/Wire
Multiple libraries were found for "SPI.h"
Used: /Users/marijn/Library/Arduino15/packages/arduino/hardware/avr/1.8.2/libraries/SPI
Using library BSEC_Software_Library at version 1.4.703 in folder: /Users/marijn/Documents/Arduino/libraries/BSEC_Software_Library
Using library Wire at version 1.0 in folder: /Users/marijn/Library/Arduino15/packages/arduino/hardware/avr/1.8.2/libraries/Wire
Using library SPI at version 1.0 in folder: /Users/marijn/Library/Arduino15/packages/arduino/hardware/avr/1.8.2/libraries/SPI
exit status 1
Error compiling for board Arduino Mega or Mega 2560.
So the sketch will not compile.
the Bosch library can be found here:
And for anyone wanting to try this sensor:
The libraries, like the one from adafruit, use bme680.c in their core from bosch. The routines for temprature, pressure and humidity are fine. The routine for Rgas has a large temperature error. It makes te sensor unusable for any enviroment with temperature swings of more then a few degrees centigrade. Like this at 12C Rgas=85.2kOhm at 15C Rgas = 62.1kOhm. I have done this from -20 to +35C The curve is fairly straight, but I would like to use a better compensated library.
This error is caused by not having a definition of compiler.c.elf.extra_flags in your platform.txt file. The entries provided in the library instructions do have this, but it is a bit confusing because they also have a commented out definition, so maybe you thought that meant you were supposed to comment out the existing definition in platform.txt. So make sure your platform.txt has this line:
compiler.c.elf.extra_flags=
It's annoying because that property didn't need any modifications anyway. It looks like they had been messing about with it to get verbose output for troubleshooting, then posted their non-standard platform.txt snippet with unnecessary modifications and pointless commented out lines instead of posting a snippet from a stock platform.txt with only the single necessary line added. It would be understandable if it's just some random hobbyist flailing about with some amateur code they wrote on the weekend, but this is a library written by Bosch to support a product they manufacture!
They now mention that you need to modify recipe.c.combine.pattern, but they neglect to say how this needs to be done on the Arduino AVR Boards platform.txt. Well, I'm a bit more considerate than our good friends at Bosch. So here's the line you need to replace it with for AVR:
On some systems a \ or a / does not matter much. OSX however is very particulair in that. Tried to find a person at Bosch to mail about that bug but ony found their regulair mail address.
marijn:
While searching for a solution I found others who used a make script to compile. My OS is too old to make that solution work.
I'm surprised. I'd expect make to more accommodating to an old OS than the Arduino IDE. I have some experience with make, and it's great in it's own way, but I have no interest in using it with Arduino sketches. My limited experience with the popular Arduino makefiles is that they don't quite work the same as the Arduino IDE, so you end up with some sketches and libraries that are not compatible, and then it's a big hassle trying to figure out what went wrong and how to fix it. That defeats the whole purpose of Arduino. If I wanted to go down that path, I'd abandon the Arduino framework altogether (which I'll never do).
marijn:
Yes, that's very annoying. I see this sort of thing in Arduino projects often. The developer is using Windows, so it works fine for them, but then some beginner tries it on a different OS and has a bad day.
Where did you find that code? If it's in a GitHub repository, I'll submit a pull request to fix the bug. I generally have good results with that approach. I rarely will bother to report bugs to an email address because I've found it usually is just a waste of time.
