Including h files from a directory above
I'd like to include a header file that I need for multiple projects. Since this file will be the same across all projects, I want to reduce redundancy and maintainability in case I need to change this file. Hence, I want to save the file in my projects folder and include it in the individual projects. My directory would look like this:
Arduino projects
- global_defines.h
- project 1
- project 2
- project n
In the files, I tried including the header file like this:
#include "../global_definitions.h"
This usually works in C++, but not in the Arduino environment.
Any tips would be appreciated.
the arduino sketch files are copied, at least on my laptop under
c:/Users/lenovo/AppData/Local/Temp
to a directory names arduino_build_xxxxx
the include is not copied because it is above your local sketch directory.
there may be a library directory you can specify
You simple create a subfolder under the folder libraries.
The naming-convention is that the name of the subfolder is exact the same as the library-name.
If they are the same you can include your special library the same way as "standard-libraries
#include <myLibrary.h>
best regards Stefan
