Including interrupt routine in library
I’m writing a library which sets up timer0 so that I can use my own implementation of millis() (note: I am not using Arduino code, only pure AVR C). Now, I’ve written a function which sets up timer and now I can’t figure out how do I include ISR routine inside a library. The code I need in lib is this:
ISR(TIMER0_COMPA_vect)  {
	//increment current time
	milliSeconds++;
milliSeconds variable is declared as volatile uint32_t and code which accesses variable is this:
uint32_t OpenDeck::rTimeMillis()	{
	//variable to hold time in ms since sketch is running
	uint32_t rTime;
	//disable interrupts during access to milliSeconds
	ATOMIC_BLOCK(ATOMIC_FORCEON) {
		rTime = milliSeconds;
	return rTime;
And it doesn't work?
So what errors did you get?
MarkT: And it doesn't work?
No, I'm getting error that milliSeconds is not declared in this scope.
Well, I agree with the compiler.
Off to http://snippets-r-us.com with you.
Make sure that you're declaring milliSeconds in a more general scope (not inside any functions, or in your OpenDeck class) before you use it in any functions.
