Including library take ram and storage?
I want to make a library that not take any storage and ram. And i'm doing a simple research at the arduino ide.
If we make a new file in the IDE and compile it, compiler return :
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
if we include a library like newping , compiler return same as not include anything :
if we include ir remote library, returns :
Sketch uses 968 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 167 bytes (8%) of dynamic memory, leaving 1881 bytes for local variables. Maximum is 2048 bytes.
Then i check the library not much different in the header (or i don't know). I want to know what's the different about including library and the structure (maybe?) in the library affect ram and storage?
Thanks!
Can you show the test sketches you used?
If your library simply defines a class, then including it, without creating an instance of the class, then no additional SRAM or FLASH memory is used.
If your library defines a bunch of global variables, then including it will cause all the global variables to be created, using SRAM but no FLASH memory.
If your library defines a class AND creates a global instance of the class, then SRAM and FLASH will be used.
Your goal of creating a library that uses no FLASH and no SRAM is completely unrealistic unless your library does nothing.
robtillaart:
Blank:
ir remote:
#include <IRremote.h>
NewPing :
#include <NewPing.h>
PaulS:
i missed something i don't mean to make library without no flash and sram but just like your first point.
Okay Understood! Thanks!
+1 for PaulS' explanation
Besides the compile time SRAM usage, more important is the runtime RAM usage.
Especially "When heap meets stack" (could be the title of a tech poem).
The function below checks the free RAM by creating a variable and calculate its position relative to some internal thingy.
int freeRam () {
    extern int __heap_start, *__brkval;
    int v;
    return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
