External Interrupts: 2 (interrupt 0), 3 (interrupt 1), 18 (interrupt 5), 19 (interrupt 4), 20 (interrupt 3), and 21 (interrupt 2). These pins can be configured to trigger an interrupt on a low level, a rising or falling edge, or a change in level.
En revanche, le doc inclus de mapping between Arduino pins and Atmega2560 ports indique des pin differents, par exemple l'interruption 5 est mappée sur le pin 3
Pin Number Pin Name Mapped Pin Name
5 PE3 ( OC3A/AIN1 ) Digital pin 5 (PWM)
6 PE4 ( OC3B/INT4 ) Digital pin 2 (PWM)
7 PE5 ( OC3C/INT5 ) Digital pin 3 (PWM)
Note that in the table below, the interrupt numbers refer to the number to be passed to attachInterrupt(). For historical reasons, this numbering does not always correspond directly to the interrupt numbering on the ATmega chip (e.g. int.0 corresponds to INT4 on the ATmega2560 chip).
