Incompatibilité compteur 5 digit et serialBegin
Bonjour,
J'ai créé un compteur de 30min grâce à un afficheur 7 segments - 4digits. Cela me donne quelque chose dans ce genre là : http://thepolyscope.com/fr/afficheur-7-segments-4-digits-arduino/
J'ai le code suivant qui fonctionne très bien et se lance à l'alimentation de l'arduino :
// Include library found at
// SevSeg library 2.3.zip - Google Drive
#include "SevSeg.h"
const int debit = 9600;
int ledPin = 0;
int speakerOut = 13;
byte names[] = {'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C'};
int tones[] = {1915, 1700, 1519, 1432, 1275, 1136, 1014, 956};
byte melody[] = "2d2a1f2c2d2a2d2c2f2d2a2c2d2a1f2c2d2a2a2g2p8p8p";
// count length: 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0
// 10 20 30
int count = 0;
int count2 = 0;
int count3 = 0;
int MAX_COUNT = 24;
int statePin = LOW;
int flag1=0;
//Create an instance of the object.
SevSeg sevseg;
unsigned long timer;
int Sec=1;
int dSec=0;
int Min=0;
int dMin=3;
int temps=0;
int desam=A1;
int explo=A3;
// Set up pins
// Arguments :
// First 0 is for common cathode
// Following 0 to 11 numbers are for Arduino pins
// connected to display in the following order
// 1,2,3,4,A,B,C,D,E,F,G,DP
sevseg.Begin(0,0,1,2,3,4,5,6,7,8,9,10,11);
pinMode(desam,INPUT);
pinMode(explo,INPUT);
do{
//Produce an output on the display
sevseg.PrintOutput();
//Check if 10ms has elapsed
unsigned long mils=millis();
if (mils-timer>=991) {
timer=mils;
Sec--;
int valdesam=analogRead(desam);
int valexplo=analogRead(explo);
if (valdesam<=1000){ goto desam;}
if (valexplo<=1000){ goto explo;}
if (Sec==-1) { // Reset to 0 after counting for 100 seconds.
Sec=9;
dSec=dSec-1;
if (dSec==-1) { // Reset to 0 after counting for 100 seconds.
dSec=5;
Min=Min-1;
if (Min==-1) { // Reset to 0 after counting for 100 seconds.
Min=9;
dMin=dMin-1;
if (dMin==-1) { // Reset to 0 after counting for 100 seconds.
Min=9;
dMin=dMin-1;
temps=Sec+10dSec+100Min+1000*dMin;
//Update the number to be displayed, with a decimal
//place in the correct position.
sevseg.NewNum(temps,(byte) 2);
}while (dMin>=-1);
goto explo;
desam :;
do{
if (flag1==0) {
Serial.begin(debit);
Serial.println("désamorcé");
Serial.end();
flag1++;
}while(1);
explo :;
analogWrite(speakerOut, 0);
for (count = 0; count < MAX_COUNT; count++) {
statePin = !statePin;
digitalWrite(ledPin, statePin);
for (count3 = 0; count3 <= (melody[count2] - 48) * 30; count3++) {
for (count2=0;count2<8;count2++) {
if (names[count2] == melody[count
2 + 1]) {
analogWrite(speakerOut,500);
delayMicroseconds(tones[count2]);
if (melody[count*2 + 1] == 'p') {
// make a pause of a certain size
do{}while(1);
Par contre dès que j'essaie de lancer le programme au déclechement d'une entrée, j'ai plus que les 2 derniers digits des secondes qui fonctionnent. J'ai repéré que cela est dû au SerialBegin mais je ne sais pas comment remplacer cela. J'ai besoin que le programme se lance lorsqu'une entrée passe à 1.
J'ai fait le programme suivant :
#include "SevSeg.h"
int ledPin = 0;
// 10 20 30
int count = 0;
int count2 = 0;
int count3 = 0;
int MAX_COUNT = 24;
int statePin = LOW;
int signal = A5; // Signal recepteur
int Val1;
int flag1=0;
SevSeg sevseg;
int Sec=1;
int dSec=0;
int Min=0;
int dMin=3;
int temps=0;
int desam=A1;
int explo=A3;
Serial.begin(9600); // Vitesse de transmission
pinMode(signal, INPUT);
// Set up pins
// Arguments :
Val1 = analogRead(signal); //Alors stocker la valeur du potard dans Val1
Serial.print("Valeur = "); // Ecrit sur l’écran "Valeur = "
Serial.println(Val1); // Ecrit sur l’écran le contenu de Val1
delay (1000); // Attente 1 seconde
if(Val1>1000)
do{
timer=mils;
Sec--;
Sec=9;
dSec=dSec-1;
dSec=5;
Min=Min-1;
Min=9;
dMin=dMin-1;
Min=9;
dMin=dMin-1;
}while (dMin>=-1);
goto explo;
desam :;
do{
if (flag1==0) {
Serial.end();
flag1++;
}while(1);
explo :;
2 + 1]) {
do{}while(1);
Savez vous d'ou peut venir mon problème ?
Merci
Tu utilises les I/O D0 et D1 qui sont dévolues à la liaison série. Il y a conflit. Essaye d'utiliser d'autres broches libres de ton arduino pour piloter ton afficheur.
slt utilise les balises code pour poster du code </>
si non tu utilise les broche 0 et 1 qui servent à la com serie, décale ton afficher et commence à partir de la borne 2 et modifie
sevseg.Begin(0,2,3,4,5,6,7,8,9,10,11,12,13);
lpour le 1er zéro je ne sais pas si il doit rester à 0 ou être à 2 ... à tester
si tu à besoin d'autres entrées tu peux lire les entrées analogique A0 à A5 comme des entrées digital
