"Incompatible types in assignment" error
Hi @all,
I am a newby, I have just bought the Arduino board, but I am already fascinated!
Because I do not know C/ C++ very well, I have a question about the following code.
Why does it not work? The Compiler always says:
In function ‘void setup()’:
error: incompatible types in assignment of ‘void’ to ‘char [20]’ In function ‘void makeString(int)’:
#include <LiquidCrystal.h>
LiquidCrystal lcd(49, 47, 45, 43, 41, 39, 37, 35, 33, 31, 29);
char printTemp[20] = "";
int mode = 1;
char buffer[20] = "";
  lcd.clear();
  buffer = makeString(mode);
  lcdPrint("Variable: ",buffer1);
// Subroutine: makeString
void makeString(int zahl) {
  char bufferMakeString[20];
  itoa (zahl,bufferMakeString,10);
  return(bufferMakeString);
// Subroutine: LCD PRINT
void lcdPrint(char textLine1[20], char textLine2[20]) {
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print(textLine1);
  lcd.setCursor(0, 1);
  lcd.print(textLine2);
void loop(){
What did I make wrong?
To be honest, I have tremendous problems with the variable types in C++!
Thank you very much for your help!!
Sebastian
You're trying to return something in a function that's defined as a void function.
Try this:
char* makeString(int zahl) {
  return bufferMakeString;
It will compile. But it will not work. This is because by the time the bufferMakeString returns to your code that calls it, the variable is no longer active in RAM. You'll need to use a global buffer variable for this.
Hi AlphaBeta,
thank you for your quick reply! Now there is the following error:
In function 'void setup()': error: incompatible types in assignment of 'char*' to 'char [20]
[UNTESTED CODE]
void setup(){ Serial.begin(9600); char* string = makeString(233445); Serial.println(string); }
void loop(){/no loop/}
char* makeString(int zahl) { itoa(zahl,bufferMakeString,10); return bufferMakeString; }
Yeah! Now it works! The LCD display shows the right number.
Here is the actual code:
int mode = 1;
  lcd.clear();
  char* string = makeString(mode);
  lcdPrint("Variable: ",string);
  lcd.clear();
void loop(){
Another question:
What happens, if I want to call makeString in the loop?
May I always use
for this?
Or is this an illegal double definition of the variable?
It's perfectly legal, but you might as well use bufferMakeString.
Now an other question:
char makedString[20];
int userSelectionMode = 1;
  lcd.clear();
  char* stringToBeJoined = makeString(userSelectionMode);
  char* lcdOutput = join3Strings("Mode ", stringToBeJoined, " selected");
  lcdPrint(lcdOutput,"");
  itoa(zahl,makedString,10);
  return makedString;
// Subroutine: join2Strings
char* join2Strings(char string1[40], char string2[40]) {
  strcat (string1, string2);
  return string1;
// Subroutine: join3Strings
char* join3Strings(char string1[40], char string2[40], char string3[40]) {
  strcat (string1, string3);
  return string1;
  lcd.clear();
void loop(){
The important thing seems to be in “Subroutine: join3Strings”.
The result on the Display is “Mode 1”, not “Mode 1 selected”, as expected.
Is there a logical problem in there?
I just wanted to add these strings…
By the way: I think, the "join3String" function does work. If you call it with " char* lcdOutput = join3Strings("Mode ", "1", " selected");" it works properly.
