Incompatible types in assignment
im trying to convert from “non asynchttp” to “ESPAsyncWebServer” for esp32. i need to collect some form data from the server and process it.
My original code “non async”
//  server.on("/", [] {if (server.hasArg("ssid") && server.hasArg("Password")) {
//server.arg("ssid").toCharArray(ssid, 15);
//  server.arg("Password").toCharArray(password, 15) ;
//  server.send(200, "text/html", "wifi set");
//  delay(1000);
//  ESP.restart();
this is what i have so far,
#include <WiFi.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
#include <AsyncElegantOTA.h>
const char* st_ssid = "........";
const char* password = "........";
AsyncWebServer server(80);
char ssid [10];
void setup(void) {
  WiFi.mode(WIFI_STA);
  WiFi.begin(st_ssid, password);
  Serial.println("");
  // Wait for connection
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to ");
  Serial.println(ssid);
  Serial.print("IP address: ");
  server.on("/", HTTP_GET, [](AsyncWebServerRequest * request) {
    if (request->hasParam("ssid") && request->hasParam("password")) {
      ssid = request->getParam("ssid")->value();
       password = request->getParam("passsword")->value();
      request->send(200, "text/html", "wifi set");
      ESP.restart();
//  delay(1000);
//  ESP.restart();
    request->send(200, "text/plain", "Hi! I am ESP32.");
void loop(void) {
the compiler complains,
exit status 1
incompatible types in assignment of 'const String' to 'char [10]'
how am i suppose to process the form data for a char array?
Please explain exactly what this line is doing
well i dont know anything about function pointers but i assume i was way off. this is what i ended up with,
request->getParam("ssid")->value().toCharArray(_EEPROM.sta_ssid, 15);
hopefully that is correct.
now i need to make this work. this is a little over my head,
bool loadFromSpiffs(String path) {
  String dataType = "text/plain";
  if (path.endsWith("/")) path += "index.htm";
  if (path.endsWith(".src")) path = path.substring(0, path.lastIndexOf("."));
  else if (path.endsWith(".html")) dataType = "text/html";
  else if (path.endsWith(".htm")) dataType = "text/html";
  else if (path.endsWith(".css")) dataType = "text/css";
  else if (path.endsWith(".js")) dataType = "application/javascript";
  else if (path.endsWith(".png")) dataType = "image/png";
  else if (path.endsWith(".gif")) dataType = "image/gif";
  else if (path.endsWith(".jpg")) dataType = "image/jpeg";
  else if (path.endsWith(".ico")) dataType = "image/x-icon";
  else if (path.endsWith(".xml")) dataType = "text/xml";
  else if (path.endsWith(".pdf")) dataType = "application/pdf";
  else if (path.endsWith(".zip")) dataType = "application/zip";
  //File dataFile = LittleFS.open(path.c_str(), "r");
  File dataFile = SPIFFS.open(path.c_str(), "r");
  if (server.hasArg("download")) dataType = "application/octet-stream";
  if (server.streamFile(dataFile, dataType) != dataFile.size()) {
  dataFile.close();
  return true;
besides the function pointer i see argument ssid convert tochararry()
I’m trying to make that function comptible, this is hat i have now,
   if (request->hasParam("download")) dataType = "application/octet-stream"; {
 // if (server.hasArg("download")) dataType = "application/octet-stream";
  dataFile.close();
  return true;
im getting compiler error,
exit status 1
'request' was not declared in this scope
exit status 1
'class AsyncWebServer' has no member named 'streamFile'
can you please help show me how to make this function work
here is the whole program,
#include <WiFi.h>
#include <SPIFFS.h>
char ssid [10];
void setup(void) {
   SPIFFS.begin();
  Serial.println("");
    Serial.print(".");
  Serial.println("");
     request->getParam("ssid")->value().toCharArray(ssid, 9);
    // ssid = ssid0.toCharArray(ssid, 9);
     //  password = request->getParam("passsword")->value();
      ESP.restart();
  AsyncElegantOTA.begin(&server);    // Start ElegantOTA
  server.begin();
  Serial.println("HTTP server started");
void notFound(AsyncWebServerRequest *request) {
  request->send(404, "text/plain", "Not found");
  dataFile.close();
  return true;
void loop(void) {
  AsyncElegantOTA.loop();
i simply need a function to load file from spiffs. i do not want to write function after function to load specific filenames 1 at a time. my previous function when presented with a known filetype will load it and the correct datatype and load it up into a response for the client.
I have read documentation but they all show use of specific file names only. I have provided an example of what the function needs to do.
THANKS!! your cocky little comment REALLY HELPED MY SITUATION!
