incompletete input while deserialze json although have set timeout
hello i am newbie at arduinojson. I want to parse the datajson from serial (sent raspi then hc12). when I print the data that I receive is correct but the deserialization process is always incomplete. what should i do to fix it?
int session = 1;
int id = 1;
int stand  = 100;
  bytecounthc12 = -1 ;
  yield();
  char Bufferhc12[len];
  bytecounthc12 = HC12.readBytesUntil('#', Bufferhc12, len);    /
  datastrhc12 = "";
  yield();
    if (bytecounthc12  > 0) {
      checkdatahc12 = true;
        for (int i = 0; i < bytecounthc12; i++) {
          datastrhc12 += Bufferhc12[i];
          if(datastrhc12.length() == len) {
            Serial.println(datastrhc12);
//String datastrhc12 ="{\"sessionid\": 1,\"idmeter\": [1,2,3],\"standmeter\": [0,0,0],\"state\": [false,false,false],\"uplink\": false}";
            //datastrhc12 = '\0'; //nullterminated dibutuhkan untuk json string
StaticJsonDocument<350> doc;
            Serial.setTimeout(10000);
            DeserializationError err = deserializeJson(doc,Serial);
              if(err) {
                Serial.print(F("deserializeJson() failed: "));
                Serial.println(err.c_str());
                return;
if the deserialization process could run i expected get new data like fig 2 (fyi deserialize running because i define variable input manually in tet editor arduino like this
String input = "{\"sessionid\": 1,\"idmeter\": [1,2,3],\"standmeter\": [0,0,0],\"state\": [false,false,false],\"uplink\": false}";
and why couldnt if read from serial?
if i use readStringUntil data doesnt complete so using readbyte so much better.
help me plese for deserialize process, Thanks before
Your duplicate topic has been deleted
Why did you create a new one ?
Third post deletion.
@husna297
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting HAS resulted in a 48 hour time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
