Incomprehensible phenomena, compiler or library function bugs?
the ps/2 mouse emulator, ps2_mouse
i modify code
unsigned char val;
// send the mouse start up
mouse.write(0xAA);
Serial.println("setup 1");
mouse.write(0x00);
Serial.println("setup 2");
delay(10);
int n = 0;
unsigned char c;
if ((digitalRead(3)==LOW) || (digitalRead(2) == LOW))
Serial.print("try read ");
Serial.println(n, HEX);
while (mouse.read(&c))
Serial.print("read fail ");
Serial.println("read ok");
//mousecommand(c);
n++;
Serial.println("end read");
//if (enabled) {
// // move the mouse diagonally
// delta_x = 1;
// delta_y = 1;
// write_packet() ;
delay(50);
Weirdly, comment out "mousecommand", will endless loop in "while (mouse.read(&c)) " by first called
print log:
16:02:27.891 ->
16:02:27.891 -> setup 1
16:02:29.502 -> setup 2
16:02:29.502 -> try read 0
16:02:29.536 -> read fail 0
16:02:29.570 -> read fail 0
16:02:29.604 -> read fail 0
16:02:29.638 -> read fail 0
16:02:29.672 -> read fail 0
16:02:29.705 -> read fail 0
16:02:29.739 -> read fail 0
16:02:29.772 -> read fail 0
16:02:29.806 -> read fail 0
16:02:29.840 -> read fail 0
16:02:29.874 -> read fail 0
16:02:29.907 -> read fail 0
16:02:29.941 -> read fail 0
16:02:29.974 -> read fail 0
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
OR
http://forum.arduino.cc/index.php/topic,148850.0.html.
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :slight_smile:
