Inconsistant WiFi page fetch time from local server
I have got my NodeMCU working well now connecting to my local server. The one thing I still need to work out is the inconsistency of the time it takes to fetch a page from the server. Mostly it takes 5ms but sometimes it spikes up to anything between 50ms or 150ms and very occasionally 3600ms.
I put a load over various sized capacitors on the power line so that shouldn’t be causing the issue. Is there a way to add a timeout to client.connect() so if it takes longer then 20ms it stops and retries the connection? For my application to work I need it to consistently take less then 90ms per request.
#include <ESP8266WiFi.h>
char ssid[] = "virginmedia54841";
char pass[] = "ljksdfli30";
const char* host = "192.168.0.27";
IPAddress server(192,168,0,27);
WiFiClient client;
  delay(100);
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, pass);
    Serial.print(".");
  Serial.println("Connected to wifi");
  unsigned long testStartTime = millis();
  if (client.connect(server, 80)) {
    client.print(String("GET ") + "/index.php HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "User-Agent: ArduinoWiFi/1.1" +
               "Connection: close\r\n\r\n");
    client.println();
    Serial.println("connection failed");
  Serial.println(millis() - testStartTime);
  client.stop();
  delay(100);
