Inconsistent analog values
Hello,
I am working on a project using analog data, and have found some inconsistencies. Since my code is a bit strange if you aren't familiar if the project. I'm looking a the simple functions within my code.
I've noticed that when I print A0 with the average subtracted and the absolute value of the latter, I get different integers (besides the negative sign). Sometime they are both right (the same integers), and sometime they are close but not quite exact. I need a lot of precise for this project. Anythoughts? It might be easier to see what I am trying to explain if you run it yourself.
int sensorPin = A0;
int average = 2000;
int sensorValue = 0;
  // initialize the serial communication:
  // send the value of analog input 0:
  Serial.println(analogRead(A0));
    Serial.print("//");
      Serial.println(analogRead(A0)-average);
    Serial.print("//");
   Serial.println(abs(analogRead(A0)-average));
  // wait a bit for the analog-to-digital converter
  // to stabilize after the last reading:
abs is a macro.
What Coding Badly means, I think, is that this:
is not the same as this:
   int temp = analogRead(A0)-average ;
   Serial.println(abs(temp));
because analogRead(A0) does not necessarily return the same value twice in a row, and the abs(...) macro causes evaluation to take place twice.
Precisely. Well stated.
What do you mean by macro?
And thank you for the suggestion, however I tried making that adjustment and saw no difference.
adbc22:
https://www.google.com/search?q=what+is+a+c+macro
https://github.com/arduino/Arduino/blob/master/hardware/arduino/avr/cores/arduino/Arduino.h#L94
I am struggling to find your new code. Perhaps you forgot to post it.
Call analogRead () once and assign that value to a variable. Then do all of your calculations and Serial.println (), etc. with the variable.
