Inconsistent SD card initialization
I can't consistently initialize SD card in my application. It randomly succeeds and fails.
I use Arduino Uno and SunFounder SD card reader.
SD card - 32G formatted as MS-DOS FAT
Here is the code
#include <Arduino.h>
#include <SD.h>
    if (!SD.begin(SPI_QUARTER_SPEED, 19)) {
        Serial.println("cannot initialize card");
        Serial.println("looks good");
I use analog pin as CS.
I don't have any capacitors, resistors etc in the schema. How can I investigate what is going on there? How to fix it?
Did u read the very first post in this section?
  • check cables.. (replace)
  • try with other card
Yes I did,
Even with non-OS formatting, sd initialization is not consistent. I used recommended formatter an the same results.
