Inconsistent serial monitor output
Hi, with this code as TX when I monitor the output window in SM I see sometimes button B come on when I connect button A to +5V -
I am using pull_down resistor 10K. - arduino Pro mini 5V
Am I doing something wrong?
// Define variables
int L_Button = LOW;
int R_Button = LOW;
#include <SPI.h>
#include "RF24.h"
#include "printf.h"
RF24 radio(9, 10);
// Controller Address
const uint64_t Controller_1 = 0xE8E8F0F0E1LL;
/*-----( Declare Variables )-----*/
uint8_t command[16]; // 2 element array of unsigned 8-bit type, holding readings
  Serial.begin(115000);
  printf_begin();
  pinMode(2, INPUT); // A Button
  pinMode(3, INPUT); // B Button
  radio.begin();
  radio.setDataRate(RF24_250KBPS);
  radio.openWritingPipe(Controller_1);
  radio.printDetails();
  Buttons();
  delay(50);
void Buttons(void)
  // Check Buttons
  L_Button = digitalRead(2);
  R_Button = digitalRead(3);
  if (R_Button == 1)
    command[0] = 1; // Command to turn on
    Serial.println("A Button 1");
    command[0] = 0; // Turn off
  if (L_Button == 1)
    command[1] = 1; // Command to turn on
    Serial.println("B Button 1");
    command[1] = 0; // Turn off
  Send_Data();
// Function to send the data
void Send_Data(void)
  radio.write(command, sizeof(command));
  //Serial.println("0");
So pin 2 is A, pin 3 is B ...
pin 2 is also L, pin 3 is R, deduction: A is L, B is R
So why are we printing "A button 1" when B button is pressed and vice versa? ...
if (R_Button == 1)
  if (L_Button == 1)
Yes, you are not reading your code before posting.
If a pin is floating it will follow the pins next to it... Basically a floating pin is undefined, if you want
it defined use INPUT_PULLUP or an external pull-up or pull-down.
@ Tammytam, printing to see what it is doing ( the state ) - I don't get you . what should I Print? maybe I miss explained - are you talking about the swapping of the buttonName?,,if so that is not the problem , I will correct it , what I am saying is that if I keep button A or B pressed/touched/+5V it eventually triggers the vice versa button (like noise or something call it) instead of it behaving independently
@MarkT : defining input is not equal to Pull down?
it is setup as : -0V ---<---10K----<---Pin2 ----->+5V
Corrected.
if (R_Button == 1)
    Serial.println("R Button pressed");
  if (L_Button == 1)
    Serial.println("L Button Pressed");
