Inconsistent Timer1 output signal
Hello!
I've been trying to generate a variable frequency signal using Timer1 from ATmega328.
I cannot understand why the output signal looks like in the picture
Imgur
It's having that empty spaces at random moments when the signal is staying low for some time.
They are not appearing at the same frequencies everytime it's random.
The prescaler is set to 256 and the timer is running in Fast-PWM mode having ICR1 as top value.
The
Did someone encountered this problem before?
If yes how did you manage it?
I will post my code below. Thank you!
  pinMode(9, OUTPUT);
  TCCR1A =  bit(COM1A1) | bit(COM1B1) |  bit(WGM11);
  TCCR1B = bit(WGM12) | bit(WGM13) | bit(CS12) ;
 // TIMSK1 |= (1 << OCIE1A); //enabling timer1 interrupt
unsigned int i=50000;
  i=50000;
  while(10 < i)
    OCR1A = i/2;
    ICR1 = i;
    i--;
    delayMicroseconds(100);
  while(i < 50000)
    OCR1A = i/2;
    ICR1 = i;
    i++;
https://imgur.com/o4mhGcb
Post the picture to this forum, not some temporary web storage.
You don't synchronize your register modifications with the actual timer status. If you modify the register while the counter is in that region you loose an event.
