Incorrect GPS Altitude (NeoGPS lib)
As part of a larger project, I’d like to find the altitude of my arduino from its GPS (NEO-M8N).
The GPS works and I can get lat/lon/UTC date, but I can’t get the altitude value to be anything except 0 (it should be ~252 meters). My code also manually changes the parameters such as manually set the report frequency to 10Hz, baud to 115200, and disable all NMEA sentences except GPGGA and GPRMC. These two sentences should have all the info I care about.
As the title states, I’m using Devin’s NeoGPS lib. Again, the GPS stuff is only a small part of a large code-base and the GPS code is contained to a single header file. Here is the file:
#pragma once
#include "Arduino.h"
#include <NMEAGPS.h>
#include "AutopilotControls.h"
#include "Board.h"
NMEAGPS gps;
gps_fix fix;
FireTimer lossGPSTimer;
#define GPS_PORT Serial1
#define LOSS_GPS_TIMEOUT 1000
#define GPS_DEFAULT_PORT_BAUD 38400
#define GPS_PORT_BAUD 115200
#define GPS_REFRESH   10
#define GPGGA_ENABLED 1
#define GPGLL_ENABLED 0
#define GPGSV_ENABLED 0
#define GPGSA_ENABLED 0
#define GPRMC_ENABLED 1
#define GPVTG_ENABLED 0
#define GNGRS_ENABLED 0
#define GNGST_ENABLED 0
#define GNZDA_ENABLED 0
#define GNGBS_ENABLED 0
#define GNDTM_ENABLED 0
#define NMEA_LEN 16
#define FREQ_LEN 14
#define BAUD_LEN 28
#define GPGGA 0
#define GPGLL 1
#define GPGSA 2
#define GPGSV 3
#define GPRMC 4
#define GPVTG 5
#define GNGRS 6
#define GNGST 7
#define GNZDA 8
#define GNGBS 9
#define GNDTM 10
#define NMEA_ID_POS  7
#define DDC_POS      8
#define SERIAL_1_POS 9
#define SERIAL_2_POS 10
#define USB_POS      11
#define SPI_POS      12
#define BAUD_0 14
#define BAUD_1 15
#define BAUD_2 16
#define BAUD_3 17
#define MEAS_RATE_1 6
#define MEAS_RATE_2 7
#define NAV_RATE_1  8
#define NAV_RATE_2  9
#define LIMITER_PERIOD 20
const char CFG_MSG[NMEA_LEN] = {
  0xB5, // Header char 1
  0x62, // Header char 2
  0x06, // class
  0x01, // id
  0x08, // length LSB
  0x00, // length MSB
  0xF0, // payload (NMEA sentence ID char 1)
  0x00, // payload (NMEA sentence ID char 2)
  0x00, // payload I/O Target 0 - DDC           - (1 - enable sentence, 0 - disable)
  0x00, // payload I/O Target 1 - Serial Port 1 - (1 - enable sentence, 0 - disable)
  0x00, // payload I/O Target 2 - Serial Port 2 - (1 - enable sentence, 0 - disable)
  0x00, // payload I/O Target 3 - USB           - (1 - enable sentence, 0 - disable)
  0x00, // payload I/O Target 4 - SPI           - (1 - enable sentence, 0 - disable)
  0x00, // payload I/O Target 5 - Reserved      - (1 - enable sentence, 0 - disable)
  0x00, // CK_A
  0x00  // CK_B
const char CFG_RATE[FREQ_LEN] = {
  0xB5, // sync char 1
  0x62, // sync char 2
  0x06, // class
  0x08, // id
  0x06, // length LSB
  0x00, // length MSB
  0x64, // payload measRate (ms) 1
  0x00, // payload measRate (ms) 2
  0x00, // payload navRate (cycles) 1
  0x00, // payload navRate (cycles) 2
  0x01, // payload timeRef 1
  0x00, // payload timeRef 2
  0x00, // CK_A
  0x00  // CK_B
const char CFG_PRT[BAUD_LEN] = {
  0x06, // class
  0x00, // id
  0x14, // length LSB
  0x00, // length MSB
  0x01, // payload portID
  0x00, // payload reserved0
  0x00, // payload txReady 1
  0x00, // payload txReady 2
  0xD0, // payload mode 1
  0x08, // payload mode 2
  0x00, // payload mode 3
  0x00, // payload mode 4
  0x00, // payload baudRate 0 (LSB)
  0x00, // payload baudRate 1
  0x00, // payload baudRate 2
  0x00, // payload baudRate 3 (MSB)
  0x07, // payload inProtoMask 1
  0x00, // payload inProtoMask 2
  0x03, // payload outProtoMask 1
  0x00, // payload outProtoMask 2
  0x00, // payload reserved4 1
  0x00, // payload reserved4 2
  0x00, // payload reserved5 1
  0x00, // payload reserved5 2
  0x00, // CK_A
  0x00  // CK_B
bool gpsConnected;
void insertChecksum(char packet[], const byte len)
  uint8_t ck_a = 0;
  uint8_t ck_b = 0;
  // exclude the first and last two bytes in packet
  for (byte i = 2; i < (len - 2); i++)
    ck_a += packet[i];
    ck_b += ck_a;
  packet[len - 2] = ck_a;
  packet[len - 1] = ck_b;
void readGPSData()
  if (fix.valid.status)
    if (fix.valid.location)
      plane.lat = fix.latitude();
      plane.lon = fix.longitude();
      //record that fix data is valid
      validFlags |= FIX_VALID;
      plane.lat = 0;
      plane.lon = 0;
      //record that fix data is not valid
      validFlags &= ~(byte)FIX_VALID;
    if (fix.valid.date)
      plane.UTC_year  = fix.dateTime.year;
      plane.UTC_month = fix.dateTime.month;
      plane.UTC_day   = fix.dateTime.date;
      plane.UTC_year  = 0;
      plane.UTC_month = 0;
      plane.UTC_day   = 0;
    if (fix.valid.time)
      plane.UTC_hour   = fix.dateTime.hours;
      plane.UTC_minute = fix.dateTime.minutes;
      plane.UTC_second = fix.dateTime.seconds;
      plane.UTC_hour   = 0;
      plane.UTC_minute = 0;
      plane.UTC_second = 0;
    if (fix.valid.speed)
      plane.sog = fix.speed_kph();
      plane.sog = 0;
    if (fix.valid.heading)
      plane.cog = fix.heading();
      plane.cog = 0;
    Serial.println(fix.altitude());
    if(fix.valid.altitude)
      plane.alt = fix.altitude();
      plane.alt = 0;
void changeFreq(uint16_t hertz)
  uint16_t normHerz = hertz / (1000 / ((CFG_RATE[MEAS_RATE_2] << 8) | CFG_RATE[MEAS_RATE_1]));
  char configPacket[FREQ_LEN];
  memcpy(configPacket, CFG_RATE, FREQ_LEN);
  configPacket[NAV_RATE_1] = (char)(normHerz & 0xFF);
  configPacket[NAV_RATE_2] = (char)((normHerz >> 8) & 0xFF);
  insertChecksum(configPacket, FREQ_LEN);
  GPS_PORT.write(configPacket, FREQ_LEN);
void changeBaud(uint32_t baud)
  char configPacket[BAUD_LEN];
  memcpy(configPacket, CFG_PRT, BAUD_LEN);
  configPacket[BAUD_0] = (char)(baud & 0xFF);
  configPacket[BAUD_1] = (char)((baud >> 8) & 0xFF);
  configPacket[BAUD_2] = (char)((baud >> 16) & 0xFF);
  configPacket[BAUD_3] = (char)((baud >> 24) & 0xFF);
  insertChecksum(configPacket, BAUD_LEN);
  GPS_PORT.write(configPacket, BAUD_LEN);
  delay(100);
  GPS_PORT.flush();
  GPS_PORT.begin(baud);
void setSentence(char NMEA_num, bool enable)
  char configPacket[NMEA_LEN];
  memcpy(configPacket, CFG_MSG, NMEA_LEN);
  if (enable)
    configPacket[SERIAL_1_POS] = 1;
  configPacket[NMEA_ID_POS] = NMEA_num;
  insertChecksum(configPacket, NMEA_LEN);
  GPS_PORT.write(configPacket, NMEA_LEN);
void setupGPS()
  GPS_PORT.begin(GPS_DEFAULT_PORT_BAUD);
  lossGPSTimer.begin(LOSS_GPS_TIMEOUT);
  //disable all NMEA sentences first
  setSentence(GPGGA, false);
  setSentence(GPGLL, false);
  setSentence(GPGSA, false);
  setSentence(GPGSV, false);
  setSentence(GPRMC, false);
  setSentence(GPVTG, false);
  setSentence(GNGRS, false);
  setSentence(GNGST, false);
  setSentence(GNZDA, false);
  setSentence(GNGBS, false);
  setSentence(GNDTM, false);
  //then select the ones you want
  if (GPGGA_ENABLED)
    setSentence(GPGGA, true);
  if (GPGLL_ENABLED)
    setSentence(GPGLL, true);
  if (GPGSV_ENABLED)
    setSentence(GPGSV, true);
  if (GPGSA_ENABLED)
    setSentence(GPGSA, true);
  if (GPRMC_ENABLED)
    setSentence(GPRMC, true);
  if (GPVTG_ENABLED)
    setSentence(GPVTG, true);
  if (GNGRS_ENABLED)
    setSentence(GNGRS, true);
  if (GNGST_ENABLED)
    setSentence(GNGST, true);
  if (GNZDA_ENABLED)
    setSentence(GNZDA, true);
  if (GNGBS_ENABLED)
    setSentence(GNGBS, true);
  if (GNDTM_ENABLED)
    setSentence(GNDTM, true);
  changeFreq(GPS_REFRESH);
  if (GPS_PORT_BAUD != GPS_DEFAULT_PORT_BAUD)
    changeBaud(GPS_PORT_BAUD);
bool gpsFailover()
  if (lossGPSTimer.fire(false))
    gpsConnected = false;
    validFlags &= ~(byte)FIX_RECENT;
  return gpsConnected;
bool pollGPS()
  if (gps.available(GPS_PORT))
    fix = gps.read();
    readGPSData();
    lossGPSTimer.start();
    gpsConnected = true;
    validFlags |= FIX_RECENT;
  return gpsFailover();
Especially this portion (always prints 0 even when real/valid data is available):
      plane.alt = 0;
Has anyone had success with getting altitude with this lib? Any suggestions?
Have you made sure that the GPGGA sentence is actually being transmitted by the GPS unit? (beware GNGGA etc.).
This simple echo program (modify as required for pins and Baud rates) will show that:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); //(RX, TX) check correct pin assignments.
  mySerial.begin(9600);
  Serial.println("GPS start");
  while (mySerial.available()) {
    Serial.write(mySerial.read());
Yes, I've previously tested that GPGGA is received by the Arduino
Actually, I just noticed that this module has a slight naming difference in it's NMEA sentence identifiers. Instead of GPGGA, it's actually GNGGA - could this be the issue???
Example output (redacted lat/lon):
$GNRMC,225212.60,A,-,-,-,-,0.259,,080920,,,A*-
$GNGGA,225212.60,-,-,-,-,1,03,3.76,257.4,M,-33.5,M,,*-
See ALL of the first line of reply #1.
Those lines are from GNSS systems. NeoGPS and/or TinyGPS++ can be instructed to decode them.
jremington:
-_-
Of course, I know this - I just don't understand why NeoGPS isn't decoding the altitude portion of the GNGGA sentence
Did you TELL it to decode the GNGGA sentence?
Do I have to tell the lib specifically what sentences to decode? I figured this would decode every sentence it could get its hands on:
    fix = gps.read();
    readGPSData(); // <-- the snippet from the previous post resides in this function
My understanding is that by default, the library is configured minimally and you need to activate the sentences you want to decode.
I’ve never used it for GNxxx sentences, as my older GPS modules don’t output them, but others on this forum have reported having the same problem.
Thanks for the help, I feel like I understand the library a little more, but it turns out the lib is already configured to handle both GPGGA and GNGGA sentences. My issue strangely turned out to be due to some processing in the datalogging part of the code and is fixed now.
