Good day!
I am new to Arduino and inexperienced with I2C and was hoping I could get help with a software-related issue I am having. The project I am working on has the following setup:
Basically, a Seeeduino Xiao MCU communicates via I2C with three sensors (temperature, light and accelerometer) and stores the readings on the SD card before returning to sleep mode.
I have managed to implement this but I am having an issue with the MAX4009 ambient light sensor. Without the sleep mode implemented I can communicate with all three sensors perfectly but once sleep mode is used the other two sensors take a reading but not the light sensor.
The output :
|accel x y z | Temperature | Ambient light
| X:-356 | Y:-355 | Z:-355 | 22.50C | 376012.81lux |
| X:-138 | Y:902 | Z:-145 | 22.99C | 376012.81lux |
| X:-150 | Y:898 | Z:-141 | 23.23C | 376012.81lux |
| X:-159 | Y:899 | Z:-142 | 23.95C | 376012.81lux |
This is the code:
#include <RTC_SAMD21.h.>
#include <DateTime.h>
#include <EnergySaving.h>
#include <SPI.h>
#include <SD.h>
#include<Wire.h>
#include <DFRobot_LIS2DW12.h>
DFRobot_LIS2DW12_I2C acce(&Wire, 0x19);
#include <Adafruit_TMP006.h>
#define Address_GY49 0x4A // Ambient Sensor I2C Address is 0x4A(74)
#define PIN_LED 13
Adafruit_TMP006 tmp006; // TMP006 Temperature sensor
EnergySaving myPowSave;
RTC_SAMD21 myRtc;
const int chipSelect = 3;
SD.begin(chipSelect);
myRtc.begin();
\\RTC Setup for Stand - by mode
myRtc.adjust(DateTime(2030, 4, 1, 8, 30, 0) );
myRtc.attachInterrupt(dummyfunc);
myPowSave.begin(WAKE_RTC_ALARM);
myRtc.disableAlarm();
DateTime timeNow = myRtc.now();
const uint16_t uiAlmNextSec = 1000;
DateTime timeAlarm = DateTime(timeNow.year(), timeNow.month(), timeNow.day(), timeNow.hour(), timeNow.minute(), timeNow.second() + uiAlmNextSec);
myRtc.setAlarm(timeAlarm);
myRtc.enableAlarm(myRtc.MATCH_SS);
delay(300); \\ No idea what im doing with these delays. Where should they be ?
unsigned int data[2];
Wire.begin();
Wire.beginTransmission(Address_GY49);
Wire.write(0x02); // Select configuration register
Wire.write(0x42); // Continuous mode, Integration time = 200 ms
Wire.endTransmission();
delay(300);
Wire.write(0x03); // Select data register
delay(300);
Wire.requestFrom(Address_GY49, 2); // Request 2 bytes of data
// Read 2 bytes of data
if (Wire.available() == 2)
data[0] = Wire.read();
data[1] = Wire.read();
// Convert the data to lux
int exponent = (data[0] & 0xF0) >> 4;
int mantissa = ((data[0] & 0x0F) << 4) | (data[1] & 0x0F);
float luminance = pow(2, exponent) * mantissa * 0.045;
delay(300);
//Accelerometer Code (working)
String output = "";
acce.continRefresh(true);
acce.setDataRate(DFRobot_LIS2DW12::eRate_50hz);
acce.setRange(DFRobot_LIS2DW12::e2_g);
acce.setFilterPath(DFRobot_LIS2DW12::eLPF);
acce.setFilterBandwidth(DFRobot_LIS2DW12::eRateDiv_4);
acce.setPowerMode(DFRobot_LIS2DW12::eContLowPwrLowNoise2_14bit);
delay(200);
output = "| X:" + (String)acce.readAccX() + " | Y:" + (String)acce.readAccY() + " | Z:" + (String)acce.readAccZ() + " | ";
//gy-49 ambient light module (Problem)
//Temperature sensor (working)
float objt = tmp006.readObjTempC();
float diet = tmp006.readDieTempC();
String output1 = (String)objt + "*C | ";
String output2 = (String)luminance + "lux |";
output += output1 + output2;
File dataFile = SD.open("datalog6.txt", FILE_WRITE);
if (dataFile) {
dataFile.println(output);
dataFile.close();
myPowSave.standby();
//proceed after wakeup
Any suggestions will be appreciated, thank you
