Incorrect output printing to serial monitor
Hello,
I'm new to using Arduino and am having some issues with printing the right output to the serial monitor.
My code is as follows:
void setup(){
// Setting up the Serial Monitor
Serial.println("What spice do you want?");
// Initiates when we receive input from the user
if (Serial.available() > 0){
// Accepting Spice Name
String choice = Serial.readString();
choice.trim();
Serial.println(choice);
// Accepting Spice Quantity
Serial.println("How much would you like?");
int spoons = Serial.parseInt();
Serial.println(spoons);
So this should accept user input and then print those values out again. For example, if I input choice = "abcd" and spoons = "0.5" it should print as:
"abcd"
"0.5"
However, the following is the output that is observed:
"abcd"
"0"
"0.5"
I'm not very sure where the "0" is coming from and I was wondering if y'all had any ideas/suggestions to address it?
Thank you for your time!
Set the serial monitor line ending control to "none" or "no line ending"
Welcome to the forum
Please follow the advice on posting code given in Read this before posting a programming question in order to make your sketch easy to read, copy and test
In particular note the advice to Auto format code in the IDE and to use code tags when posting code here as it prevents some combinations of characters in code being interpreted as HTML commands such as italics, bold or a smiley character, all of which render the code useless
If the code exceeds the 9000 character inline limit then attach it to a post
