Incorrectly reading LoRa data: M0 Feather and radiohead
Hi there,
I am trying to make a RX, TX code with an Adafruit M0 Feather (has RFM9X built in) using the radiohead library. I am making a test code of sorts to transmit a string that changes from "Button A" to "Button B' every cycle of my loop. In the RX code I made I am trying to read that message and then send back a message depending on which phrase was sent from the TX. Both of my programs compile fine but I am unable to accurately read the phrase (the code always goes to the else statement despite the phrase "Button A" being sent).
I am sure this is a simple fix but I haven't been able to figure it out. Attached are the RX code, TX code, and Serial monitor outputs for RX and TX. Thanks!!
RX Code
// Feather9x_RX
// -*- mode: C++ -*-
// Example sketch showing how to create a simple messaging client (receiver)
// with the RH_RF95 class. RH_RF95 class does not provide for addressing or
// reliability, so you should only use RH_RF95 if you do not need the higher
// level messaging abilities.
// It is designed to work with the other example Feather9x_TX
#include <SPI.h>
#include <RH_RF95.h>
// First 3 here are boards w/radio BUILT-IN. Boards using FeatherWing follow.
#if defined (__AVR_ATmega32U4__)  // Feather 32u4 w/Radio
  #define RFM95_CS    8
  #define RFM95_INT   7
  #define RFM95_RST   4
#elif defined(ADAFRUIT_FEATHER_M0) || defined(ADAFRUIT_FEATHER_M0_EXPRESS) || defined(ARDUINO_SAMD_FEATHER_M0)  // Feather M0 w/Radio
  #define RFM95_CS    8
  #define RFM95_INT   3
  #define RFM95_RST   4
#elif defined(ARDUINO_ADAFRUIT_FEATHER_RP2040_RFM)  // Feather RP2040 w/Radio
  #define RFM95_CS   16
  #define RFM95_INT  21
  #define RFM95_RST  17
#elif defined (__AVR_ATmega328P__)  // Feather 328P w/wing
  #define RFM95_CS    4  //
  #define RFM95_INT   3  //
  #define RFM95_RST   2  // "A"
#elif defined(ESP8266)  // ESP8266 feather w/wing
  #define RFM95_CS    2  // "E"
  #define RFM95_INT  15  // "B"
  #define RFM95_RST  16  // "D"
#elif defined(ARDUINO_ADAFRUIT_FEATHER_ESP32S2) || defined(ARDUINO_NRF52840_FEATHER) || defined(ARDUINO_NRF52840_FEATHER_SENSE)
  #define RFM95_CS   10  // "B"
  #define RFM95_INT   9  // "A"
  #define RFM95_RST  11  // "C"
#elif defined(ESP32)  // ESP32 feather w/wing
  #define RFM95_CS   33  // "B"
  #define RFM95_INT  27  // "A"
  #define RFM95_RST  13
#elif defined(ARDUINO_NRF52832_FEATHER)  // nRF52832 feather w/wing
  #define RFM95_CS   11  // "B"
  #define RFM95_INT  31  // "C"
  #define RFM95_RST   7  // "A"
#endif
/* Some other possible setups include:
// Feather 32u4:
#define RFM95_CS   8
#define RFM95_RST  4
#define RFM95_INT  7
// Feather M0:
#define RFM95_CS   8
#define RFM95_RST  4
#define RFM95_INT  3
// Arduino shield:
#define RFM95_CS  10
#define RFM95_RST  9
#define RFM95_INT  7
// Feather 32u4 w/wing:
#define RFM95_RST 11  // "A"
#define RFM95_INT  2  // "SDA" (only SDA/SCL/RX/TX have IRQ!)
// Feather m0 w/wing:
#define RFM95_INT  6  // "D"
// Change to 434.0 or other frequency, must match RX's freq!
#define RF95_FREQ 915.0
// Singleton instance of the radio driver
RH_RF95 rf95(RFM95_CS, RFM95_INT);
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(RFM95_RST, OUTPUT);
  digitalWrite(RFM95_RST, HIGH);
  while (!Serial) delay(1);
  delay(100);
  Serial.println("Feather LoRa RX Test!");
  // manual reset
  digitalWrite(RFM95_RST, LOW);
  delay(10);
  delay(10);
  while (!rf95.init()) {
    Serial.println("LoRa radio init failed");
    Serial.println("Uncomment '#define SERIAL_DEBUG' in RH_RF95.cpp for detailed debug info");
    while (1);
  Serial.println("LoRa radio init OK!");
  // Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM
  if (!rf95.setFrequency(RF95_FREQ)) {
    Serial.println("setFrequency failed");
    while (1);
  Serial.print("Set Freq to: "); Serial.println(RF95_FREQ);
  // Defaults after init are 434.0MHz, 13dBm, Bw = 125 kHz, Cr = 4/5, Sf = 128chips/symbol, CRC on
  // The default transmitter power is 13dBm, using PA_BOOST.
  // If you are using RFM95/96/97/98 modules which uses the PA_BOOST transmitter pin, then
  // you can set transmitter powers from 5 to 23 dBm:
  rf95.setTxPower(23, false);
  if (rf95.available()) {
    // Should be a message for us now
    uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
    uint8_t len = sizeof(buf);
    if (rf95.recv(buf, &len)) {
      digitalWrite(LED_BUILTIN, HIGH);
      RH_RF95::printBuffer("Received: ", buf, len);
      char* phrase = (char*)buf;
      Serial.print("Got: ");
      Serial.println((char*)buf);
      Serial.println(strlen((char*)buf));
      Serial.print("RSSI: ");
      Serial.println(rf95.lastRssi(), DEC);
      Serial.println(phrase);
      char data[20] = "Motor is #";
      if (phrase=="Button A"){
        motorOn();
        data[9] = 'H';
        Serial.println("Check");
      else{
        motorOff();
        data[9] = 'L';
      // Send a reply
      rf95.send((uint8_t*)data, sizeof(data));
      rf95.waitPacketSent();
      Serial.println("Sent a reply");
      digitalWrite(LED_BUILTIN, LOW);
      Serial.println("Receive failed");
void motorOn(){
  Serial.println("Turned motor on!");
void motorOff(){
  Serial.println("Turned motor off!");
TX Code
// Feather9x_TX
// Example sketch showing how to create a simple messaging client (transmitter)
// It is designed to work with the other example Feather9x_RX
#include <SPI.h>
  #define RFM95_CS    8
  #define RFM95_INT   7
  #define RFM95_RST   4
  #define RFM95_CS    8
  #define RFM95_INT   3
  #define RFM95_RST   4
  #define RFM95_CS   16
#endif
// Feather 32u4:
#define RFM95_CS   8
#define RFM95_RST  4
#define RFM95_INT  7
// Feather M0:
#define RFM95_CS   8
#define RFM95_RST  4
#define RFM95_INT  3
// Arduino shield:
#define RFM95_CS  10
#define RFM95_RST  9
#define RFM95_INT  7
int count=0;
  delay(100);
  Serial.println("Feather LoRa TX Test!");
  // manual reset
  delay(10);
  delay(10);
    while (1);
    while (1);
int16_t packetnum = 0;  // packet counter, we increment per xmission
  delay(1000); // Wait 1 second between transmits, could also 'sleep' here!
  Serial.println("Transmitting..."); // Send a message to rf95_server
  char radiopacket[9] = "Button #";
  if (count%2==0){
    radiopacket[7] = 'A';
  else{
   radiopacket[7] = 'B';
  radiopacket[8] = 0;
  count++;
  Serial.print("Sending "); Serial.println(radiopacket);
  Serial.println("Sending...");
  delay(10);
  rf95.send((uint8_t *)radiopacket, strlen(radiopacket));
  Serial.println("Waiting for packet to complete...");
  delay(10);
  // Now wait for a reply
  Serial.println("Waiting for reply...");
  if (rf95.waitAvailableTimeout(1000)) {
    // Should be a reply message for us now
      Serial.print("Got reply: ");
    Serial.println("No reply, is there a listener around?");
RX Serial Output
TX Serial Output
This is not valid C/C++. To compare character strings (zero terminated character arrays), use the function strcmp().
It is valid and much simpler to compare single characters, for example
char c = Serial.read();
if (c == 'A') Serial.println("character A received");
// or
     if (buf[7] == 'A') take_action();
Drop the "(char *)" in the following lines. It does nothing useful, since buf is already a pointer to a C-string.
I incorporated strcmp() and that was the answer. Thank you!
Glad that fixes it!
In Arduino preferences, it is a good idea to turn on verbose compiler messages. That way you will see warnings about such errors.
I am running into another issue it seems like. When I read the buffer in my RX code the length of the string is not the same (there are some random characters seemingly appended to it). Do you know what causes this?
TX Code
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
/************ OLED Setup ***************/
Adafruit_SSD1306 oled = Adafruit_SSD1306();
#if defined(ESP8266)
  #define BUTTON_A  0
  #define BUTTON_B 16
  #define BUTTON_C  2
  #define LED       0
#elif defined(ESP32) && !defined(ARDUINO_ADAFRUIT_FEATHER_ESP32S2)
  #define BUTTON_A 15
  #define BUTTON_B 32
  #define BUTTON_C 14
  #define LED      13
#elif defined(ARDUINO_STM32F2_FEATHER)
  #define BUTTON_A PA15
  #define BUTTON_B PC7
  #define BUTTON_C PC5
  #define LED      PB5
#elif defined(TEENSYDUINO)
  #define BUTTON_A  4
  #define BUTTON_B  3
  #define BUTTON_C  8
  #define LED      13
  #define BUTTON_A 31
  #define BUTTON_B 30
  #define BUTTON_C 27
  #define LED      17
  #define BUTTON_A  9
  #define BUTTON_B  6
  #define BUTTON_C  5
  #define LED      LED_BUILTIN
#else  // 32u4, M0, and 328p
  #define BUTTON_A  9
  #define BUTTON_B  6
  #define BUTTON_C  5
  #define LED      13
#endif
/************ Radio Setup ***************/
  #define RFM95_CS    8
  #define RFM95_INT   7
  #define RFM95_RST   4
  #define LED        13
  #define RFM95_CS    8
  #define RFM95_INT   3
  #define RFM95_RST   4
  #define LED        13
  #define RFM95_CS   16
  #define LED        13
  #define LED         0
  #define LED        13
  #define RFM95_RST  13  // same as LED
  #define LED        13
  #define LED        17
#endif
  while (!Serial) delay(1); // wait until serial console is open, remove if not tethered to computer
  // Initialize OLED display
  oled.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3C (for the 128x32)
  oled.display();
  oled.clearDisplay();
  oled.display();
  pinMode(BUTTON_A, INPUT_PULLUP);
  pinMode(BUTTON_B, INPUT_PULLUP);
  pinMode(BUTTON_C, INPUT_PULLUP);
  pinMode(LED, OUTPUT);
  Serial.println("Feather LoRa RX/TX Test!");
  // manual reset
  delay(10);
  delay(10);
  if (!rf95.init()) {
    while (1);
    while (1);
  Serial.print("LoRa radio @"); Serial.print((int)RF95_FREQ); Serial.println(" MHz");
  // OLED text display tests
  oled.setTextSize(2);
  oled.setTextColor(WHITE);
  oled.setCursor(0,0);
  oled.print("LoRa radio @ ");
  oled.print((int)RF95_FREQ);
  oled.println(" MHz");
  oled.display();
  if (!digitalRead(BUTTON_A) || !digitalRead(BUTTON_B) || !digitalRead(BUTTON_C)) {
    Serial.println("Button pressed!");
    if (!digitalRead(BUTTON_A)){
        send_message(radiopacket);
        get_message();
        delay(100);
    if (!digitalRead(BUTTON_B)){
      get_message();
      delay(100);
    if (!digitalRead(BUTTON_C)){
      radiopacket[7] = 'C';
      get_message();
      delay(100);
void send_message(char radio[9]){
  radio[8] = 0;
  Serial.print("Sending "); Serial.println(radio);
  rf95.send((uint8_t *)radio, strlen(radio));
void get_message(){
    if (! rf95.recv(buf, &len)) {
      return;
    digitalWrite(LED, HIGH);
    Serial.print("Got: "); Serial.println((char*)buf);
    Serial.print("RSSI: "); Serial.println(rf95.lastRssi(), DEC);
    oled.println((char*)buf);
    oled.print("RSSI: "); oled.print(rf95.lastRssi());
    oled.display();
RX Code
// Feather9x_RX
#include <SPI.h>
  #define RFM95_CS    8
  #define RFM95_INT   7
  #define RFM95_RST   4
  #define RFM95_CS    8
  #define RFM95_INT   3
  #define RFM95_RST   4
  #define RFM95_CS   16
#endif
// Feather 32u4:
#define RFM95_CS   8
#define RFM95_RST  4
#define RFM95_INT  7
// Feather M0:
#define RFM95_CS   8
#define RFM95_RST  4
#define RFM95_INT  3
// Arduino shield:
#define RFM95_CS  10
#define RFM95_RST  9
#define RFM95_INT  7
  delay(100);
  // manual reset
  delay(10);
  delay(10);
    while (1);
    while (1);
      uint8_t phrase[] = {buf[len-1]};
      int val = strcmp((char *)phrase, "A");
      Serial.println(val);
      //Serial.println(phrase);
      if (val==0){
        motorOn();
        data[9] = 'H';
      else{
        motorOff();
        data[9] = 'L';
      // Send a reply
void motorOn(){
void motorOff(){
TX Serial
RX Serial
I suspect it is something wonky with the Serial printing because the hex code received does in fact correspond to the string "Button A"
This line does not send the terminating zero byte of the C-string. You have to be aware of that, and add it back in at the receiving end.
Or to include the zero, use
  rf95.send((uint8_t *)radio, strlen(radio)+1);
