I am interfacing Arduino Mega with Biometric Fingerprint module R307.
How can I increase more than 162 Biometric ID fingerprints ? Is there any way to increase or that is the maximum ID limit ? I am using Arduino Adafruit FingerPrint Sensor Library.
I am new to Arduino kindly help .
Thanks in Advance,
Stark.
That link doesn't work.
Think about how much space is needed to record one fingerprint. Think about where they are stored. Think about how much storage space is available. Does that limit seem unreasonable?
I believe that you can dump fingerprint data out of the device and equally, upload it. So conceivably, you could maintain a library of templates and switch them out as needed, but since you can't have more than 162 loaded at once, it seems it would be of limited use.
wildbill:
How to take fingerprint data ? how to dump fingerprint data and upload it into arduino for more than 300 fingerprints ?
Is there any possiblities to store fingerprint bmp file?
PaulS:
Since im very begineer to Arduino I am searching how to record one Fingerprint in storage space of BioMetric.
How to analyse where it is stored ?
How to check how much storage space available ?
Thank you, for the response. Now, I got to store and detect biometric ID's upto 1000.Because, I modified that library file(adafurit fingerprint sensor).
starksoundar:
Hi sir.
How or what did you modify in the library please? I have been trying with no result...
philipnganda:
Hi sir.
Thanks though. I got it. Changed 0xA3 to 0x3E8 for 1000 fingerprints, or 0xFF for 255 fingerprints
philipnganda:
... the capacity increased to 255, not 1000.i think that I'll have to mess around with the uint8_t s in the library....
philipnganda:
here, I changed that 0x01 to 0x02 in the library where the Id store and get.
[quote author=starksoundar date=1548234483 link=msg=4029694]
[/quote]
Thanks for the response.
I can't yet figure it out.
Here's the cpp.h
This is a library for our optical Fingerprint sensor
Designed specifically to work with the Adafruit Fingerprint sensor
----> http://www.adafruit.com/products/751
These displays use TTL Serial to communicate, 2 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include "Adafruit_Fingerprint.h"
#if defined(__AVR__) || defined(ESP8266)
#include <SoftwareSerial.h>
#endif
//#define FINGERPRINT_DEBUG
Adafruit_Fingerprint::Adafruit_Fingerprint(SoftwareSerial *ss) {
thePassword = 0;
theAddress = 0xFFFFFFFF;
hwSerial = NULL;
swSerial = ss;
mySerial = swSerial;
#endif
Adafruit_Fingerprint::Adafruit_Fingerprint(HardwareSerial *ss) {
thePassword = 0;
swSerial = NULL;
#endif
hwSerial = ss;
mySerial = hwSerial;
void Adafruit_Fingerprint::begin(uint16_t baudrate) {
delay(1000); // one second delay to let the sensor 'boot up'
if (hwSerial) hwSerial->begin(baudrate);
if (swSerial) swSerial->begin(baudrate);
#endif
#define GET_CMD_PACKET(...) \
uint8_t data[] = {__VA_ARGS__}; \
Adafruit_Fingerprint_Packet packet(FINGERPRINT_COMMANDPACKET, sizeof(data), data); \
writeStructuredPacket(packet); \
if( getStructuredPacket(&packet) != FINGERPRINT_OK || packet.type != FINGERPRINT_ACKPACKET ) { return FINGERPRINT_PACKETRECIEVEERR; }
#define SEND_CMD_PACKET(...) GET_CMD_PACKET(__VA_ARGS__); return packet.data[0];
boolean Adafruit_Fingerprint::verifyPassword(void) {
GET_CMD_PACKET(FINGERPRINT_VERIFYPASSWORD,
(uint8_t)(thePassword >> 24), (uint8_t)(thePassword >> 16),
(uint8_t)(thePassword >> 8), (uint8_t)(thePassword & 0xFF));
return packet.data[0] == FINGERPRINT_OK;
uint8_t Adafruit_Fingerprint::getImage(void) {
SEND_CMD_PACKET(FINGERPRINT_GETIMAGE);
uint8_t Adafruit_Fingerprint::image2Tz(uint8_t slot) {
SEND_CMD_PACKET(FINGERPRINT_IMAGE2TZ,slot);
uint8_t Adafruit_Fingerprint::createModel(void) {
SEND_CMD_PACKET(FINGERPRINT_REGMODEL);
uint8_t Adafruit_Fingerprint::storeModel(uint16_t id) {
SEND_CMD_PACKET(FINGERPRINT_STORE, 0x02, (uint8_t)(id >> 8), (uint8_t)(id & 0xFF));
//read a fingerprint template from flash into Char Buffer 1
uint8_t Adafruit_Fingerprint::loadModel(uint16_t id) {
SEND_CMD_PACKET(FINGERPRINT_LOAD, 0x01, (uint8_t)(id >> 8), (uint8_t)(id & 0xFF));
//transfer a fingerprint template from Char Buffer 1 to host computer
uint8_t Adafruit_Fingerprint::getModel(void) {
SEND_CMD_PACKET(FINGERPRINT_UPLOAD, 0x02);
uint8_t Adafruit_Fingerprint::deleteModel(uint16_t id) {
SEND_CMD_PACKET(FINGERPRINT_DELETE, (uint8_t)(id>>8), (uint8_t)(id & 0xFF), 0x00, 0x01);
uint8_t Adafruit_Fingerprint::emptyDatabase(void) {
SEND_CMD_PACKET(FINGERPRINT_EMPTY);
uint8_t Adafruit_Fingerprint::fingerFastSearch(void) {
// high speed search of slot #1 starting at page 0x0000 and page #0x00A3
GET_CMD_PACKET(FINGERPRINT_HISPEEDSEARCH, 0x01, 0x00, 0x00, 0x00, 0x3E8);
fingerID = 0xFFFF;
confidence = 0xFFFF;
fingerID = packet.data[1];
fingerID <<= 8;
fingerID |= packet.data[2];
confidence = packet.data[3];
confidence <<= 8;
confidence |= packet.data[4];
uint8_t Adafruit_Fingerprint::getTemplateCount(void) {
GET_CMD_PACKET(FINGERPRINT_TEMPLATECOUNT);
templateCount = packet.data[1];
templateCount <<= 8;
templateCount |= packet.data[2];
#if ARDUINO >= 100
#define SERIAL_WRITE(...) mySerial->write(__VA_ARGS__)
#else
#define SERIAL_WRITE(...) mySerial->write(__VA_ARGS__, BYTE)
#endif
#define SERIAL_WRITE_U16(v) SERIAL_WRITE((uint8_t)(v>>8)); SERIAL_WRITE((uint8_t)(v & 0xFF));
void Adafruit_Fingerprint::writeStructuredPacket(const Adafruit_Fingerprint_Packet & packet) {
SERIAL_WRITE_U16(packet.start_code);
SERIAL_WRITE(packet.address[0]);
SERIAL_WRITE(packet.address[1]);
SERIAL_WRITE(packet.address[2]);
SERIAL_WRITE(packet.address[3]);
SERIAL_WRITE(packet.type);
uint16_t wire_length = packet.length + 2;
SERIAL_WRITE_U16(wire_length);
uint16_t sum = ((wire_length)>>8) + ((wire_length)&0xFF) + packet.type;
for (uint8_t i=0; i< packet.length; i++) {
SERIAL_WRITE(packet.data[i]);
sum += packet.data[i];
SERIAL_WRITE_U16(sum);
return;
uint8_t Adafruit_Fingerprint::getStructuredPacket(Adafruit_Fingerprint_Packet * packet, uint16_t timeout) {
uint8_t byte;
uint16_t idx=0, timer=0;
while(true) {
while(!mySerial->available()) {
delay(1); timer++; if(timer>=timeout) return FINGERPRINT_TIMEOUT;
byte = mySerial->read();
switch(idx) {
case 0:
if(byte != FINGERPRINT_STARTCODE>>8) continue;
packet->start_code = byte << 8;
case 1:
packet->start_code |= byte & 0xFF;
if(packet->start_code != FINGERPRINT_STARTCODE) return FINGERPRINT_BADPACKET;
case 2:
case 3:
case 4:
case 5:
packet->address[idx-2] = byte;
case 6: packet->type = byte; break;
case 7: packet->length = byte << 8; break;
case 8: packet->length |= byte & 0xFF; break;
default:
packet->data[idx-9] = byte;
if((idx-8) == packet->length)
return FINGERPRINT_OK;
idx++;
[code][quote author=starksoundar date=1548234483 link=msg=4029694]
[/quote]
Here's the cpp.h
interface
#endif
thePassword = 0;
hwSerial = NULL;
swSerial = ss;
#endif
thePassword = 0;
swSerial = NULL;
#endif
hwSerial = ss;
#endif
fingerID = 0xFFFF;
fingerID <<= 8;
confidence <<= 8;
#if ARDUINO >= 100
#else
#endif
return;
uint8_t byte;
while(true) {
switch(idx) {
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
default:
idx++;
[/code]
starksoundar:
[/code]
I think that this is better
@brief Ask the sensor to convert image to feature template
@param slot Location to place feature template (put one in 1 and another in 2 for verification to create model)
@returns <code>FINGERPRINT_OK</code> on success
@returns <code>FINGERPRINT_IMAGEMESS</code> if image is too messy
@returns <code>FINGERPRINT_PACKETRECIEVEERR</code> on communication error
@returns <code>FINGERPRINT_FEATUREFAIL</code> on failure to identify fingerprint features
@returns <code>FINGERPRINT_INVALIDIMAGE</code> on failure to identify fingerprint features
@brief Ask the sensor to take two print feature template and create a model
@returns <code>FINGERPRINT_ENROLLMISMATCH</code> on mismatch of fingerprints
@brief Ask the sensor to store the calculated model for later matching
@param location The model location #
@returns <code>FINGERPRINT_BADLOCATION</code> if the location is invalid
@returns <code>FINGERPRINT_FLASHERR</code> if the model couldn't be written to flash memory
uint8_t Adafruit_Fingerprint::storeModel(uint16_t location) {
SEND_CMD_PACKET(FINGERPRINT_STORE, 0x02, (uint8_t)(location >> 8), (uint8_t)(location & 0xFF));
@brief Ask the sensor to load a fingerprint model from flash into buffer 1
uint8_t Adafruit_Fingerprint::loadModel(uint16_t location) {
SEND_CMD_PACKET(FINGERPRINT_LOAD, 0x02, (uint8_t)(location >> 8), (uint8_t)(location & 0xFF));
@brief Ask the sensor to transfer 256-byte fingerprint template from the buffer to the UART
@brief Ask the sensor to delete a model in memory
uint8_t Adafruit_Fingerprint::deleteModel(uint16_t location) {
SEND_CMD_PACKET(FINGERPRINT_DELETE, (uint8_t)(location >> 8), (uint8_t)(location & 0xFF), 0x00, 0x01);
@brief Ask the sensor to delete ALL models in memory
@brief Ask the sensor to search the current slot 1 fingerprint features to match saved templates. The matching location is stored in <b>fingerID</b> and the matching confidence in <b>confidence</b>
@returns <code>FINGERPRINT_OK</code> on fingerprint match success
@returns <code>FINGERPRINT_NOTFOUND</code> no match made
GET_CMD_PACKET(FINGERPRINT_HISPEEDSEARCH, 0x01, 0x00, 0x00, 0x03, 0xFF);
fingerID = 0xFFFF;
fingerID <<= 8;
confidence <<= 8;
@brief Ask the sensor for the number of templates stored in memory. The number is stored in <b>templateCount</b> on success.
@brief Set the password on the sensor (future communication will require password verification so don't forget it!!!)
@param password 32-bit password code
uint8_t Adafruit_Fingerprint::setPassword(uint32_t password) {
SEND_CMD_PACKET(FINGERPRINT_SETPASSWORD, (password >> 24), (password >> 16), (password >> 8), password);
@brief Helper function to process a packet and send it over UART to the sensor
@param packet A structure containing the bytes to transmit
return;
here i modified
starksoundar:
@returns FINGERPRINT_OK
on success
@returns FINGERPRINT_IMAGEMESS
@returns FINGERPRINT_PACKETRECIEVEERR
@returns FINGERPRINT_FEATUREFAIL
@returns FINGERPRINT_INVALIDIMAGE
on success
@returns FINGERPRINT_ENROLLMISMATCH
on success
@returns FINGERPRINT_BADLOCATION
@returns FINGERPRINT_FLASHERR
if the model couldn’t be written to flash memory
on success
on success
on success
on success
@brief Ask the sensor to search the current slot 1 fingerprint features to match saved templates. The matching location is stored in fingerID and the matching confidence in confidence
@returns FINGERPRINT_NOTFOUND
no match made
fingerID = 0xFFFF;
fingerID <<= 8;
confidence <<= 8;
@brief Ask the sensor for the number of templates stored in memory. The number is stored in templateCount on success.
on success
@brief Set the password on the sensor (future communication will require password verification so don’t forget it!!!)
on success
return;
here i modified
Thanks a lot Starksoundar. It worked
if you could post the library edited version that will be of great help
thank you
starksoundar:
it worked thank you
i have "Re: INCREASE BIOMETRIC ID" can you fix error
