Hello, I have an ESP script that reads data from a sensor and saves it in an array. If 100 values are reached, the data is sent via BLE. The script is currently at 100 sample rate but had already increased it to 400. But the data that is sent is much less than 100 or 400 per second, what can be the reason? Is an ESP32 Dev. Here is the code:
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
#include <DFRobot_MAX30102.h>
DFRobot_MAX30102 particleSensor;
int Wert; // Variable die bei jedem Erfassen der Daten erhöht wird um dann bei 100 Werten das Array abzuschließen und das Senden einzuleiten
// Datenarray zum Senden von Daten über das BLE-Charakteristikum
int data[100] = {0}; // 100 Integer-Werte, initialisiert mit 0
int dataIR[100] = {0}; // 100 Integer-Werte, initialisiert mit 0
BLEServer* pServer = NULL;
BLECharacteristic* pCharacteristic = NULL;
BLECharacteristic* pCharacteristic2 = NULL;
BLECharacteristic* pCharacteristic3 = NULL;
uint32_t ledBrightness1 = 50;
uint8_t sampleAverage1 = SAMPLEAVG_4;
uint8_t ledMode1 = MODE_MULTILED;
int16_t sampleRate1 = SAMPLERATE_100;
uint16_t pulseWidth1 = PULSEWIDTH_411;
uint16_t adcRange1 = ADCRANGE_16384;
bool deviceConnected = false;
bool updateSensor = false;
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
#define SERVICE_UUID "4fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define CHARACTERISTIC_UUID "beb5483e-36e1-4688-b7f5-ea07361b26a8"
#define CHARACTERISTIC_UUID2 "beb5483e-36e1-4688-b7f5-ea07361b26a9"
#define CHARACTERISTIC_UUID3 "5a464637-3fe1-4685-9e33-ec4ba175f081"
class MyServerCallbacks: public BLEServerCallbacks {
void onConnect(BLEServer* pServer) {
deviceConnected = true;
void onDisconnect(BLEServer* pServer) {
// Diese Funktion zerlegt einen String in Teilstrings anhand eines Trennzeichens
std::vector<std::string> splitString(std::string s, std::string delimiter) {
std::vector<std::string> result;
size_t pos = 0;
std::string token;
while ((pos = s.find(delimiter)) != std::string::npos) {
token = s.substr(0, pos);
result.push_back(token);
s.erase(0, pos + delimiter.length());
result.push_back(s);
return result;
class MyCallbacks : public BLECharacteristicCallbacks {
void onWrite(BLECharacteristic *pCharacteristic) {
std::string value = pCharacteristic->getValue();
std::vector<std::string> parameters = splitString(value, " ");
for (int i = 0; i < parameters.size(); i++) {
Serial.print("Parameter empfangen");
Serial.print(i + 1);
Serial.print(": ");
Serial.println(parameters[i].c_str());
g
if (i == 0) {
ledBrightness1 = std::strtoul(parameters[i].c_str(), nullptr, 10);
if (i == 1) {
sampleAverage1 = std::strtoul(parameters[i].c_str(), nullptr, 10);
if (i == 2) {
ledMode1 = std::strtoul(parameters[i].c_str(), nullptr, 10);
if (i == 3) {
sampleRate1 = std::strtoul(parameters[i].c_str(), nullptr, 10);
if (i == 4) {
pulseWidth1 = std::strtoul(parameters[i].c_str(), nullptr, 10);
if (i == 5) {
adcRange1 = std::strtoul(parameters[i].c_str(), nullptr, 10);
std::string received_message = "Werte empfangen!";
pCharacteristic->setValue(received_message);
pCharacteristic->notify();
updateSensor = true;
void updateSensorConfig() {
particleSensor.sensorConfiguration(ledBrightness1, sampleAverage1, ledMode1, sampleRate1, pulseWidth1, adcRange1);
Serial.println("Sensor configuration updated");
while (!particleSensor.begin()) {
Serial.println("MAX30102 was not found");
particleSensor.sensorConfiguration(50, SAMPLEAVG_4, MODE_MULTILED, SAMPLERATE_100, PULSEWIDTH_411, ADCRANGE_16384);
BLEDevice::init("ESP_SPO2");
pServer = BLEDevice::createServer();
pServer->setCallbacks(new MyServerCallbacks());
BLEService *pService = pServer->createService(SERVICE_UUID);
pCharacteristic = pService->createCharacteristic(
CHARACTERISTIC_UUID,
BLECharacteristic::PROPERTY_READ |
BLECharacteristic::PROPERTY_WRITE |
BLECharacteristic::PROPERTY_NOTIFY |
BLECharacteristic::PROPERTY_INDICATE
pCharacteristic2 = pService->createCharacteristic(
CHARACTERISTIC_UUID2,
pCharacteristic3 = pService->createCharacteristic(
CHARACTERISTIC_UUID3,
pCharacteristic3->setCallbacks(new MyCallbacks());
pCharacteristic->addDescriptor(new BLE2902());
pCharacteristic2->addDescriptor(new BLE2902());
pCharacteristic3->addDescriptor(new BLE2902());
pService->start();
BLEAdvertising *pAdvertising = BLEDevice::getAdvertising();
pAdvertising->addServiceUUID(SERVICE_UUID);
pAdvertising->setScanResponse(false);
pAdvertising->setMinPreferred(0x0);
BLEDevice::startAdvertising();
Serial.println("Waiting for a client connection to notify...");
if (Wert <= 99) {
Serial.println(Wert);
data[Wert] = particleSensor.getRed();
dataIR[Wert] = particleSensor.getIR();
Wert = Wert + 1;
Wert = 0;
Serial.println("100 Werte im Array gesammelt");
Serial.println("Bin in vor Schleife Gerät Verbunden");
pCharacteristic->setValue((uint8_t*)data, sizeof(data));
pCharacteristic2->setValue((uint8_t*)dataIR, sizeof(dataIR));
pCharacteristic2->notify();
Serial.println("Sende Daten:");
if (!deviceConnected) {
Serial.println("ESP nicht verbunden. Daten: ");
for (int i = 0; i < 100; i++) {
Serial.print(data[i]);
Serial.print(" ");
pServer->startAdvertising();
Serial.println("start advertising");
if (updateSensor) {
updateSensorConfig();
