increase in temp increases rate of blink - how to without Delay or Millis?
I'm using the analog input of a voltage divider made of a thermistor (10k) and a fixed resistor (12k), to monitor a variation in temperature using the Ladyada code.
Ladyada's code is very versatile and works as expected. My goal is to add a buzzer that will beep more frequently as the temperature rises. Since I dont have any buzzer right now, I have been testing my ideas with an LED.
  1. Initially I went with a simple ON/OFF delay: fixed On delay(100) for short beeps and an OFF delay that would start at around 2000ms and become shorter as temp increased. This worked well but using "delay"...delays everything else happening, which sucks.
  2. Using Millis() also worked, however, it meant that the LED would stay ON for 2000ms and OFF for another 2000ms, when it's blinking at the lowest rate (lowest temp). This would mean having a buzzer ON for 2 seconds, which I dont want.
// which analog pin to connect
#define THERMISTORPIN A0
// resistance at 25 degrees C
#define THERMISTORNOMINAL 10000
// temp. for nominal resistance (almost always 25 C)
#define TEMPERATURENOMINAL 25
// how many samples to take and average, more takes longer
// but is more 'smooth'
#define NUMSAMPLES 5
// The beta coefficient of the thermistor (usually 3000-4000)
#define BCOEFFICIENT 3900
// the value of the 'other' resistor
#define SERIESRESISTOR 12000
//#define DEBUG
int samples[NUMSAMPLES];
int ledPin = 9;
int outputValue = 0;
unsigned long previousMillis = 0;
int ledState = LOW;
void setup(void) {
  pinMode(ledPin, OUTPUT);
  analogReference(EXTERNAL);
void loop(void) {
  uint8_t i;
  float average;
  // take N samples in a row, with a slight delay
  for (i=0; i< NUMSAMPLES; i++) {
   samples[i] = analogRead(THERMISTORPIN);
   delay(10);
  // average all the samples out
  average = 0;
     average += samples[i];
  average /= NUMSAMPLES;
  // convert the value to resistance
  average = 1023 / average - 1;
  average = SERIESRESISTOR / average;
  float steinhart;
  steinhart = average / THERMISTORNOMINAL;     // (R/Ro)
  steinhart = log(steinhart);                  // ln(R/Ro)
  steinhart /= BCOEFFICIENT;                   // 1/B * ln(R/Ro)
  steinhart += 1.0 / (TEMPERATURENOMINAL + 273.15); // + (1/To)
  steinhart = 1.0 / steinhart;                 // Invert
  steinhart -= 273.15;                         // convert to C
  // map the temperature variating from 19-30 ºC to a delay value, smaller delay faster blink
  outputValue = map(steinhart, 19, 30, 2000, 10);
  if (currentMillis - previousMillis >= outputValue) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW) {
      ledState = HIGH;
      ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(ledPin, ledState);
  //Basic delay alternative
  /*digitalWrite(ledPin, HIGH);
  delay(10);
  digitalWrite(ledPin, LOW);
  delay(outputValue);*/
  #if defined DEBUG
  Serial.print("Average analog reading ");
  Serial.println(average);
  Serial.print("Thermistor resistance ");
  Serial.print("Temperature ");
  Serial.print(steinhart);
  Serial.println(" *C");
  Serial.print("outputValue ");
  Serial.println(outputValue);
  delay(100);
  #endif
Moderator edit: CODE TAGS
So, don't have it on for two seconds.
You don't have to have the OFF time the same as the ON time.
I'm asking because I cant come up with a proper bit of code to do that.
      ledState = HIGH;
      ledState = LOW;
When you change the value of "ledState", you could also change the value of the ON time (currently "outputValue") or the OFF time.
Solved: the LED blinks more frequently as the temp rises
// number of samples
// On and Off Times (as int, max=32secs)
const unsigned int onTime = 100;
int offTime = 0;
// Tracks the last time event fired
unsigned long previousMillis=0;
// Interval is how long we wait
int interval = onTime;
// Used to track if LED should be on or off
boolean ledState = true;
const int ledPin = 9;
//#define DEBUG
void setup(void) {
void loop(void) {
  uint8_t i;
  float average;
   delay(10);
  average = 0;
  float steinhart;
  outputValue = map(steinhart, 19, 40, 2000, 10);
  // Set Pin ledPin to state of ledState each timethrough loop()
  // If ledState hasn't changed, neither will the pin
  // Grab snapshot of current time, this keeps all timing
  // consistent, regardless of how much code is inside the next if-statement
  // Compare to previous capture to see if enough time has passed
  if ((unsigned long)(currentMillis - previousMillis) >= interval) {
    // Change wait interval, based on current LED state
    if (ledState) {
      // LED is currently on, set time to stay off
      interval = outputValue;
      // LED is currently off, set time to stay on
      interval = onTime;
    // Toggle the LED's state, Fancy, eh!?
    ledState = !(ledState);
    // Save the current time to compare "later"
  #if defined DEBUG
  delay(50);
  #endif
Alternative: the pitch of a buzzer increases as temperature rises
int offTime = 0;
//#define DEBUG
void setup(void) {
void loop(void) {
  uint8_t i;
  float average;
   delay(10);
  average = 0;
  float steinhart;
  outputValue = map(steinhart, 19, 40, 0, 800);
  int pitch = 200 + outputValue;
  tone(ledPin, pitch);
  #if defined DEBUG
  delay(50);
  #endif
