This code works well one axis but the motor doesn't always shut off and it's very hard to keep the joystick exactly in the center so that the motor stays off. Anyone know how I can increase the dead zone so the joystick is not so sensitive?
#include <AccelStepper.h> // accelstepper library
AccelStepper stepper(1, 8, 9); // direction Digital 9 (CCW), pulses Digital 8 (CLK)
//Pins
const byte Analog_X_pin = A1; // x-axis readings
const byte enablePin = 7;
//Variables
int Analog_X = 0; //x-axis value
int Analog_X_AVG = 0; //x-axis value average
//PINS
pinMode(Analog_X_pin, INPUT);
pinMode(enablePin, OUTPUT);
pinMode(2, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
InitialValues(); // averaging the values of analog pin 0 (value from potmeter)
// Stepper parameters
// setting up some default values for maximum speed and maximum acceleration
stepper.setMaxSpeed(2000); //SPEED = Steps / second
stepper.setAcceleration(1000); //ACCELERATION = Steps /(second)^2
stepper.setSpeed(1000);
ReadAnalog();
ReadLimits();
stepper.runSpeed(); //step the motor (this will step the motor by 1 step at each loop indefinitely)
void ReadLimits()
if( digitalRead(2)==LOW && stepper.speed()>0 )//read input, assuming they have pull-up resistors.
stepper.setSpeed(0);
if( digitalRead(3)==LOW && stepper.speed()<0 )//read input, assuming they have pull-up resistors.
void ReadAnalog() {
if (abs(Analog_X-Analog_X_AVG) > 50) {
digitalWrite(enablePin, HIGH); // enable the driver
stepper.setSpeed(5*(Analog_X-Analog_X_AVG));
digitalWrite(enablePin, LOW); // disable the driver
// Reading the potentiometer in the joystick:
Analog_X = analogRead(Analog_X_pin);
// if the value is 25 "value away" from the average (midpoint), we allow the update of the speed
// This is a sort of a filter for the inaccuracy of the reading
stepper.setSpeed(5 * (Analog_X-Analog_X_AVG));
void InitialValues() {
//Set the values to zero before averaging
float tempX = 0;
// read the analog 50x, then calculate an average.
// they will be the reference values
for (int i = 0; i<50; i++) {
tempX += analogRead(Analog_X_pin);
delay(10); //allowing a little time between two readings
Analog_X_AVG = tempX/50;
Serial.print("AVG_X: ");
Serial.println(Analog_X_AVG);
Serial.println("Calibration finished");
