Increase MPU-6050 SD Writing Spead
Hello,
I am currently trying to record the yaw, pitch, and roll values recorded from my MPU-6050 gyroscope module. As seen in the attached text file, I was able to record at a rate of about 1 reading per 15ms or 66Hz. Ideally I would like to increase the output frequency as much as possible while still maintaining decent readability. However, I recognize that writing a simpler data type to the SD card -while harder to read- would probably be faster than the string I am currently using. Any suggestions on how I might make my code more time efficient would be greatly appreciated.
(note that the code has been trimmed to fit the 9000 character limit, and is based heavily on this MPU6050 example)
// ===                    MAIN PROGRAM LOOP                     ===
    // if programming failed, don't try to do anything
    if (!dmpReady) return;
    // wait for MPU interrupt or extra packet(s) available
    while (!mpuInterrupt && fifoCount < packetSize) {
        // other program behavior stuff here
        // if you are really paranoid you can frequently test in between other
        // stuff to see if mpuInterrupt is true, and if so, "break;" from the
        // while() loop to immediately process the MPU data
    // reset interrupt flag and get INT_STATUS byte
    mpuInterrupt = false;
    mpuIntStatus = mpu.getIntStatus();
    // get current FIFO count
    fifoCount = mpu.getFIFOCount();
    // check for overflow (this should never happen unless our code is too inefficient)
    if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
        // reset so we can continue cleanly
        mpu.resetFIFO();
        Serial.println(F("FIFO overflow!"));
    // otherwise, check for DMP data ready interrupt (this should happen frequently)
    } else if (mpuIntStatus & 0x02) {
        // wait for correct available data length, should be a VERY short wait
        while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
        // read a packet from FIFO
        mpu.getFIFOBytes(fifoBuffer, packetSize);
        // track FIFO count here in case there is > 1 packet available
        // (this lets us immediately read more without waiting for an interrupt)
        fifoCount -= packetSize;
        #ifdef OUTPUT_READABLE_QUATERNION
            // display quaternion values in easy matrix form: w x y z
            mpu.dmpGetQuaternion(&q, fifoBuffer);
            Serial.print("quat\t");
            Serial.print(q.w);
            Serial.print("\t");
            Serial.print(q.x);
            Serial.print("\t");
            Serial.print(q.y);
            Serial.print("\t");
            Serial.println(q.z);
        #endif
        #ifdef OUTPUT_READABLE_EULER
            // display Euler angles in degrees
            mpu.dmpGetEuler(euler, &q);
            Serial.print("euler\t");
            Serial.print(euler[0] * 180/M_PI);
            Serial.print("\t");
            Serial.print(euler[1] * 180/M_PI);
            Serial.print("\t");
            Serial.println(euler[2] * 180/M_PI);
        #endif
        #ifdef OUTPUT_READABLE_YAWPITCHROLL
            mpu.dmpGetGravity(&gravity, &q);
            mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
            Serial.print("Time:\t");
            Serial.print(millis()-startTime);
            Serial.print("\t");
            Serial.print("ypr\t");
            Serial.print(ypr[0] * 180/M_PI);
            Serial.print("\t");
            Serial.print(ypr[1] * 180/M_PI);
            Serial.print("\t");
            Serial.println(ypr[2] * 180/M_PI);
            // write values to sd card
            myFile.print("ypr\t");
            myFile.print(ypr[0] * 180/M_PI);
            myFile.print("\t");
            myFile.print(ypr[1] * 180/M_PI);
            myFile.print("\t");
            myFile.print(ypr[2] * 180/M_PI);
            myFile.print("\t");
            myFile.print("Time:\t");
            myFile.println(millis()-startTime);
        #endif
        #ifdef OUTPUT_READABLE_REALACCEL
            // display real acceleration, adjusted to remove gravity
            mpu.dmpGetAccel(&aa, fifoBuffer);
            mpu.dmpGetLinearAccel(&aaReal, &aa, &gravity);
            Serial.print("areal\t");
            Serial.print(aaReal.x);
            Serial.print("\t");
            Serial.print(aaReal.y);
            Serial.print("\t");
            Serial.println(aaReal.z);
        #endif
        #ifdef OUTPUT_READABLE_WORLDACCEL
            // display initial world-frame acceleration, adjusted to remove gravity
            // and rotated based on known orientation from quaternion
            mpu.dmpGetLinearAccelInWorld(&aaWorld, &aaReal, &q);
            Serial.print("aworld\t");
            Serial.print(aaWorld.x);
            Serial.print("\t");
            Serial.print(aaWorld.y);
            Serial.print("\t");
            Serial.println(aaWorld.z);
        #endif
        #ifdef OUTPUT_TEAPOT
            // display quaternion values in InvenSense Teapot demo format:
            teapotPacket[2] = fifoBuffer[0];
            teapotPacket[3] = fifoBuffer[1];
            teapotPacket[4] = fifoBuffer[4];
            teapotPacket[5] = fifoBuffer[5];
            teapotPacket[6] = fifoBuffer[8];
            teapotPacket[7] = fifoBuffer[9];
            teapotPacket[8] = fifoBuffer[12];
            teapotPacket[9] = fifoBuffer[13];
            Serial.write(teapotPacket, 14);
            teapotPacket[11]++; // packetCount, loops at 0xFF on purpose
        #endif
        // blink LED to indicate activity
        blinkState = !blinkState;
        digitalWrite(LED_PIN, blinkState);
        if (millis()-startTime > 60000)
          myFile.close();
          exit(0);
TEST.TXT (157 KB)
Have you considered FRAM (Feroresemot Random Access Memory) It's similar to Static random-access memory, only with a ferroelectric layer instead of a dielectric layer. This gives it stable handling (the bytes you write are non-volatile) with dynamic responsiveness (you can write them very fast!). Some of the advantages I see in FRAM are high speed reading and writing, non-volatile storage (it remembers its contents without needing power or battery backup), virtually unlimited read / write cycles - you can't wear it out unlike some other types of non-volatile memory. To get started try this link: Adafruit SPI Non-Volatile FRAM Breakout - 64Kbit / 8KByte : ID 1897 : $5.95 : Adafruit Industries, Unique & fun DIY electronics and kits There board has a write enable input so you can lock it down and read it on another machine without worry about trashing the date. Then when you are finished logging you can either transfer it to the SD card else where whatever works for you.
Good Luck & Have Fun!
Gil
