Increase the reference voltages
In arduino mega 2560 , I have total 16 bit inputs, 14 for data and 1 for direction and 1 for data validity. directionPin is 14, validityPin is 15, while from 22 to 35 is the data input in form on high or low (5v or gnd), similar to binary. These 14 bit should be bind to 9 or 10Volt reference.
I am facing some issues with getting the output.
I placed an external battery 9V , common the gnd with Mega ground, on +VE terminal connected a resistor (around 1K) , on the other end of resistor connected the pwm pin (9), and testing the output from second end of resistor to gnd.
is it the correct setting? I am not getting the output properly, while showing correctly on Serial Monitor
here is the code.
const int referenceVoltage = 10; // Reference voltage
const int directionPin = 14; //  direction (15th bit)
const int validityPin = 15; // data validity (16th bit)
const int pwmPin = 9;
  pinMode(pwmPin, OUTPUT);
  int data = 0;
  for (int i = 22; i < 36; i++) {
    int bit = digitalRead(i);
    data |= bit << (i - 22);
  int direction = digitalRead(directionPin);
  int validity = digitalRead(validityPin);
  if (validity == HIGH) {
    float outputVoltage = (float)data / 16383.0 * referenceVoltage;
    // Set PWM duty cycle based on the output voltage
    int pwmValue = map(outputVoltage, 0, referenceVoltage, 0, 255);
    analogWrite(pwmPin, pwmValue);
    Serial.print("Received data: ");
    Serial.print(data);
    Serial.print("Received data (binary): ");
    for (int i = 13; i >= 0; i--) {
      Serial.print((data >> i) & 0x01);
    Serial.print(", Direction: ");
    Serial.print(direction == LOW ? "Forward" : "Reverse");
    Serial.print(", Data Validity: ");
    Serial.print(validity == HIGH ? "Valid" : "Invalid");
    Serial.print(", Analog Output Voltage: ");
    Serial.print(outputVoltage);
    Serial.print("PWM Value:");
    Serial.println(pwmValue);
    analogWrite(pwmPin, 0);
    Serial.println("Invalid data received.");
what do you mean exactly with that?
should we understand that you need to read in the 14 data bits (GND / 5V) from pins 22 to 35 and build a PWM signal cycling between GND and 9 or 10V output from pin 9?
pin 9 cannot be at anything other than GND or 5V - so you'll need to drive some sort of power circuit from that pin, a mosfet / transistor or may be just an optocoupler that is fast enough for your needs
If this is what you are doing, then you will burn out your mega
Please use the language of pen and paper, spelled schematics.
Yes, this is something I am doing.
Here is the schematic as asked by @Railroader
It might help to understand what I am trying to achieve.
Thanks.
A serial resistor from 10 volt to pin 9 might damage the controller. Use a voltage divider. What are You intending to do with that connection?
Never apply any voltage directly to an output pin.
Never apply any voltage greater than 5V directly or indirectly to any pin.
Are you trying to creat a PWM output that goes from 0V to 10V?
Yes, I am trying to do it by enabling these data pins, like mentioned in the image. based on the enable bits it should generate output from 0-10 volt.
for more clarification, I just want that output should be based on the below bits enable or disable.
1100 0000 0000 0000 = 0V
1111 1111 1111 1111 = 10V
Hope I am able to explain what I want to do.
how much current do you need to drive on the load side with 0 - 10V ?
not more than which a port required to operate relay module. probably 15-20mA. or whatever these ports can generate at once.
so driving a simple transistor or an optocoupler will do (any inductive load ?)
Yes but what will be connected to the 10V PWM signal?
It will become the input for a machine, that operates based on these bits.
Yes, if required, as it become input for a machine that will operates based on these bit, if more current required then it will be adjusted through transistor or optocouplers. but first basic requirements need to be achieved.
OK, now I see what you want to do.
Basically, you are designing a 16 bit DAC (Digital to Analog Converter) by using PWM to generate a 0 to 10V analog output.
You can do that but you will need a good opamp, a 12V supply, and a few resistors and capacitors.
I’ll see if I can find an opamp that will work.
OR
You can buy a DAC module and just use an opamp the increase the voltage to 10V
OR a 10V DAC module
Up to you, either way will work.
Correct me please that It will generate Analog voltages, while I want to have DC volt.
Analog voltages can be AC or DC so you can output a DC voltage with the PWM method or using a DAC
The DAC linked in post #16 outputs a DC voltage, with a value chosen from the range of 0 to 10V.
Seems you are trying to make a 0 ~ 10V DAC with 14 bit (610.35µV) resolution. Is that correct?
