Hey all. Trying to increase a variable when a button is pressed;
I have:
if (State <= 0 && State <= 20)
xDis=30;
if (State >= 0)
yDis=1;
if (State >= 1)
yDis=2;
if (State >= 2)
yDis=3;
But this seems tedious, and I want the yDis
variable to go from 0-10 in 0.5 increments. Is there a better, simplier way to write this instead of 20 if
statements?
Full code:
#include<Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
//define State Var (for button)
int State;
//def xDis and yDis
int xDis;
float yDis; //needs to be float, since it goes up Y.YYft increments
const int MPU_addr=0x68;
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
int minVal=265;
int maxVal=402;
double x;
double y;
double z;
void setup(){
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B);
Wire.write(0);
Wire.endTransmission(true);
Serial.begin(57600);
//button setup
pinMode(4,INPUT);
//new
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
Wire.setClock(400000);
Wire.begin();
delay(250);
Wire.beginTransmission(0x68);
Wire.write(0x6B);
Wire.write(0x00);
Wire.endTransmission();
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("SSD1306 allocation failed"));
for(;;);
void loop(){
Wire.write(0x3B);
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true);
AcX=Wire.read()<<8|Wire.read();
AcY=Wire.read()<<8|Wire.read();
AcZ=Wire.read()<<8|Wire.read();
int xAng = map(AcX,minVal,maxVal,-90,90);
int yAng = map(AcY,minVal,maxVal,-90,90);
int zAng = map(AcZ,minVal,maxVal,-90,90);
x= RAD_TO_DEG * (atan2(-yAng, -zAng)+PI);
y= RAD_TO_DEG * (atan2(-xAng, -zAng)+PI)-90;
z= RAD_TO_DEG * (atan2(-yAng, -xAng)+PI);
Serial.print("AngleX= ");
Serial.println(x);
Serial.print("AngleY= ");
Serial.println(y);
Serial.print("AngleZ= ");
Serial.println(z);
Serial.println("-----------------------------------------");
// add delay if needed
delay(0);
//button
int ButtonPress = digitalRead(4);
if (ButtonPress==0)
State=State+1;
Serial.println(State);
delay(50);
if (State >= 20)
State=0;
// Determine Distance
//X=30ft and y increments
xDis=30;
if (State >= 0)
yDis=0;
if (State >= 1)
yDis=0.5;
if (State >= 2)
yDis=1;
if (State >= 3)
yDis=1.5;
//display items and objectives (angles)
display.clearDisplay();
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(0, 0);
// Display distance text
display.print("Distance:(");
display.print(xDis);
display.print(",");
display.print(yDis);
display.print(")ft");
display.setCursor(0, 6);
display.println("=-=---------------=-=");
// Display Current Angle
display.setCursor(0, 16);
display.println("Current Angle:");
// Display Target Angle
display.setCursor(0, 28);
display.setTextSize(2);
display.println(y);
float TargetAngle = 4.95;
display.setCursor(0, 56);
display.print("Target Angle:");
display.print(TargetAngle);
display.display();
