Increasing Brightness Linearly
I understand that LED brightness seems to be logarithmic as a function of duty cycle. In other words, perceived brightness = log(duty cycle) or that as the duty cycle becomes higher, the perceived differences in brightness become more imperceptible.
A person on the AVR Freaks forum posted this thread on how to use the formula "brightness = log(10^(duty cycle)) = x" to cancel out the log using a lookup table or linear interpolation.
Is there a name for this kind of "linearizing using the inverse"? I searched wikipedia and found "Inverse problem" but it got complicated really quickly with matrices and I couldn't follow.
what is the colour of the LED as IIRC these formulas depend on the colour too.
If you want to implement a lookup table check multimap() - http://playground.arduino.cc/Main/MultiMap -
My particular LEDs were green and white.
The logarithmic curve is only a relatively coarse approximation. More accurate is the CIE LAB correction:
http://neuroelec.com/2011/04/led-brightness-to-your-eye-gamma-correction-no/
This post on the forum explains how to calculate a lookup table:
http://forum.arduino.cc/index.php/topic,147810.0.html
You may want to check out “progmem”:
http://arduino.cc/en/Reference/PROGMEM
Just to leave as reference in google searches, here’s a little code that reasonably compensates our vision tendency and makes it seem like a linear brightness increase.
double LightLevel = 0;
double Base = 0.0039215;
    while (LightLevel < 255) {  // 1020 increments up to 255
    analogWrite(LightLevelPin, LightLevel);
    LightLevel = pow(Base, 4) ;
    Base = Base + 0.0039215;
It’s not a problem of the leds, it’s a “problem” with our eyes. Double the duty the brightness does double. But our eyes don’t see it as doubling.
What you want is gamma correction. I would not do it on the fly because the calculation is a bit heavy (not impossible but not easy for an 8-bit chip). In my library I use gamma correction as well :slight_smile:
