Hi.
I have created a piece of code which produces 2 PWM signals which are phase-shifted 180°. Duty cycle is variable from 0 to around 50%. Using Arduino UNO
Problem is, that I would like to know how to increase frequency to around 40kHz or even something higher.
I have tried reading different guides and documents, but having practically no experience with Arduino and direct port manipulation, I have hard time understading it.
So far I understand that I am using timer0 and it is in phase-correct PWM mode. If I change it to fast-pwm I increase frequency, BUT signal won’t be phase shifted. I need signals to be shifted 180°
int dutyCycle;
int a;
void setup() // do something with timers.
pinMode (5, OUTPUT);
pinMode (6, OUTPUT);
//TCCR0A = bit (WGM10) | bit (COM0B1) | bit (COM0A1) | bit (COM0A0);
TCCR0A = bit (COM0B1) | bit (COM0A1) | bit (COM0A0);
TCCR0A |= (1 << WGM10);
TCCR0B = 0x01;
a = map(analogRead(A0), 0, 1023, 140, 255);
dutyCycle = a;
OCR0A = dutyCycle; // duty cycle out of 255
OCR0B = 255 - dutyCycle; // duty cycle out of 255
Duty cycle is adjusted with a pot on analog 0 pin. Output pins are 5 and 6. Adjusting duty cycle doesn’t affect shift between signals.
So I would like have some directions or ideas how to solve it. I would appreciate it very much.
