increasing I/O pins in arduino also voltmeter
Hello all once again thanks for all the help i recieved thus far my project is coming along nicely but im running into some problems i have like 3 atmega chips im really only using one is there a way i can connect two of them to increase the number of pins cause i just ran out of I/Os,...or whats the easiest way to increase the number of I/O's ....plus in my project i need to measure the voltage of a system with a voltmeter used by a user and when they check it have the numerical information inputed back to the microcontroller code and checked against additional information. Is there a chip that i can add to my design that does that or a way i can open a voltmeter and rewire it to do such....ANY IDEAS FOLKS
Adding extra inputs or outputs is something people do all the time. There are many ways to do this, the most popular is by using a shift register.
Depending on if you want extra inputs or outputs use:-
Or:-
For general interfacing see:-
http://www.arduino.cc/playground/Main/InterfacingWithHardware
You can use the analogue input of the arduino with a suitable potential divider to measure voltage.
I presume you need more pins than the new Arduino Mega provides? It has something like 54 digital pins and 15 analog.
