Increasing output of the Flex sensor for servos
I've made a robot hand which moves via a servo. See it here https://www.youtube.com/watch?v=WYUPK2AXYjs
The problem is that this version uses a potentiometer to get that range of movement but I want to use the flex sensor which just makes the fingers wiggle a bit.
How do I increase the range of movement with a flex sensor?
Thank you
You could use the map() function: http://arduino.cc/en/Reference/map
servo.write(map(flex_value, MIN_FLEX_VALUE, MAX_FLEX_VALUE, 0, 180);
or
servo.writeMicroseconds(map(flex_value, MIN_FLEX_VALUE, MAX_FLEX_VALUE, 1000, 2000);
