I am using 16 pins connected to 4 Edited: L293NE motorcontrollers.
However, my steppers have very little torque.
I was previously using a 5 volt, 1 amp power adapter, but this provided very little power, I then shifted to a 9 volt battery, run in series with 3 1.5 volt batteries, but this produced little noticeable change.
I am new to motorcontrol and was wondering where I am going wrong?
What matters most to stepper motors (really, any motor) is the current. The more current, the more torque.
Now, voltage gets into the mix since it is the force by which current flows. In a stepper motor, you change the direction of current in each coil to make it take steps. The faster you can change the direction of current, the more torque you will get. The more current there is after the direction has changed, the more torque you will get.
So higher voltages only help with the first part: changing the direction of current faster. That helps a bit, but is no substitute for having a power supply that can deliver the current needed.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, speaker, microphone, light sensor, potentiometer, pushbuttons
No need to drop the voltage down, you can use PWM (analogWrite()) to keep the current within the motor's limits. The PWM is applied to the EN (enable) pin of your motor drivers. Setting a 50% duty cycle PWM from an 18V source is (mostly) equivalent to leaving a 9V source on full time.
You just have to watch out for low-inductance coils, as high voltage can exceed your motor driver's instantaneous current. Your steppers have 46mH/coil so should be OK.
And it seems to me that inductance is determined by the size or space between the coils? If so, how do I know how low/high my sizes should be?
Or is this just something you learn with experience?
Finally, I've been using the Arduino stepper library, do I need to rework my code to allow for the inclusion of PWM? as at the moment I have the steppers declared as stepper1...stepper4
and I just use stepper1.step(30); to send a signal.
I can use 4 of my analog pins to output analogWrite(127); to the EN pin of my 4 motor driver chips, and this will reduce the voltage by half?
Yes, that should work. It reduces the effective power to the motors, not the voltage, but that's splitting hairs.
Inductance is a property of the motor coils. Generally the more powerful the motor the greater the inductance. What matters most is the ratio of inductance to coil resistance (L/R). If this value is small then you can have problems for low PWM frequencies. Your L/R is 0.046/34=1.4ms so as long as your PWM frequency (not duty cycle) is around 1/1.4ms=730 Hz or faster it should be OK, and I seem to remember that's what the Arduino analogWrite() frequency is (or thereabouts).
No changes should be required as the stepper library just controls the step sequencing. It doesn't do anything with the ENABLE lines in a typical bipolar motor setup. Those are under your control.
In general high performance stepper motors just quote the current and inductance - it is assumed they will be current-driven rather than voltage driven. Typical high-performance stepper controllers run from anything upto 50V using PWM to step down to the actual voltage required (which depends on the actual motor speed).
Stepper motors with a high resistance winding like yours are designed for ease of control (voltage drive) rather than motor performance (high speed and high torque). Yours is rated for 12V, drive it from 12v to get its rated behaviour.
The main rule is don't exceed the rated current (this can cause overheating and/or magnetic saturation) - so you can improve things by moving to a current-controlling PWM driver circuit (set for a max of 0.33A, 12V or more), but don't use a direct (non PWM) driver greater than 12V. Because of the high-inductance high-resistance windings the max speed will not be as high as a high-performance motor.
RuggedCircuits:
Unless changed, the Arduino PWM frequency is 500 Hertz.
The standard Arduino runs timer0 as fast PWM and timer1/timer2 as phase-correct PWM. They are all set to divide-by-64 prescale - this means that pins 3, 9, 10, 11 are about 500Hz and pins 5 and 6 are about 1kHz. It could be worthwhile increasing the frequency by reconfiguring the prescale values.
Sorry about that MarkT the motorcontroller is actually an L293NE.
My teammate has rigged up 4 L7812CV http://www.alldatasheet.com/datasheet-pdf/pdf/22640/STMICROELECTRONICS/L7812CV.html voltage regulators between a 19 volt 3.42 amp and the 4 motorcontrollers. Is this a possible way we should go about incorporating a more powerful power supply into the circuit? We were told this would work by someone at the electronics store, but when the voltage regulators are added, all that happens is the voltage regulator for the first stepper gets really really hot.
Thanks for being patient. Will there be an issue with the motorcontroller chip receiving too much power without a voltage regulator?
This is the sample code I've rigged up to test the motor rotation:
#include <Stepper.h>
#define STEPS 200
// create an instance of the stepper class, specifying
// the number of steps of the motor and the pins it's
// attached to
Stepper stepper1(STEPS, 2, 3, 4, 5);
Stepper stepper2(STEPS, 6, 7, 8, 9);
Stepper stepper3(STEPS, 10, 11, 12, 13);
Stepper stepper4(STEPS, A0, A1, A2, A3);
const int analogWritePin = 4;
// set the speed of the motor to 30 RPMs
stepper1.setSpeed(10);
stepper2.setSpeed(10);
stepper3.setSpeed(10);
stepper4.setSpeed(10);
//Where analogWritePin is connected to the en pins of each of the 4 hbridges.
analogWrite(analogWritePin, 127);
stepper1.step(20);
stepper2.step(20);
stepper3.step(20);
stepper4.step(20);
The L293 drivers you are using are rated for operation up to 36V so 19V operation should be fine with them. Just keep an eye on the current -- those things are not internally thermal limited so if they get too hot they will be destroyed. I know they say they are rated for 0.6A/1A (depending on the L293/L293D variant) but really that's a marketing number. Read this. The L293 is probably a little underpowered for the kind of torque/current you're looking for.
Interesting read, so a L293 actually reduces the amount of current going through it in order to sustain itself.
It doesn't really "steal" current to sustain itself. The power loss is just due to the nature of the transistors inside the L293 -- they dissipate power when current goes through them, typically more than more modern FET-based drivers. That's power that doesn't get to your motors.
Regarding current, a 3.5 amp current flow from the power source would likely be too much? Or will enabling PWM help mitigate that?
That depends on your power source. You say you've got a 19V 3.42A power supply, so it should be able to handle 420.33=2.64A of currents.
Also, is my code a viable implementation of PWM using analogWrite?
Yes, assuming you hook everything up right! (as your code says, pin D4 connected to the EN pin of all drivers). Though that can't be right because you instantiate your stepper1() instance of Stepper to use pins 2,3,4,5. So you're already using pin 4. You need to think about your wiring more.
