Increasing two different servo PWM's with different delay's
I have a program running a couple of sail winch servos to control some clock face hands. One servo for hour hand, one for minute hand.
I have the minute hand working well using a delay to incrementally increase the pwm to simulate the minutes, simulating a real
clock.
The servo takes +235PWM to do a full rotation so for the minute hand I have been increasing the PWM by 2 increments every 30 seconds
(Maths bit - 235PWM / 60mins = 3.9PWM per min so - 4PWM per min (rough, but ok for what I need) = 2PWM per 30 seconds.
The code below works fine for the minute hand however I have now come to doing the hour hand and I need to find a way of having
two different delays, or an alternative method to have the pwm’s increasing at different speeds.
(Hour hand maths bit - 4PWM (1 Min clock time) x 10mins (1 hr clock time) = 40PWM per 60 mins ‘real time’
40PWM / 60mins = 1.5PWM Per min =
1.5 increments per minute or 3 increments every two minutes (due to not being able to use 0.5 of a PWM)
I hope this makes sense,
basically I want to know if
1/there is a way of increasing, incrementally the two different PWM’s with different delays within the same case?
2/does anyone know if servo’s can use fractions of a PWM, for example 1503.9PWM? or will this just cause problems?
Thanks in advance, please no suggestions of using Steppers etc, I have to use servos’s for this particular setup for reasons
that will take too long to explain here.
// I HAVE TAKEN OUT THE HOUR HAND CODE FOR NOW, MINUTE HAND CODE WORKS FINE
case 7: // Commence Time
  MinutePulse = MinutePulse + 2;  //incremental time increase every 30 seconds (30000)
    //HourPulse = HourPulse + 3; //incremental time increase needs to be every two minutes (120000)
  MinuteHand.writeMicroseconds(MinutePulse);
    //HourHand.writeMicroseconds(HourPulse);
    //Serial.print("HOUR PWM VALUE IS SET TO ");
    //Serial.println(HourPulse);
  Serial.print("MINUTE PWM VALUE IS SET TO ");
  Serial.println(MinutePulse);
  delay (30000);
Some clocks have second and minute hands that jump to the next position - once per second or once per minute. I take it that is not what you are trying to do.
I'll admit that I don't really understand what you are trying to do. It seems to me that either there is a constant writeMicroseconds() value that will cause the second hand to sweep once per minute, or there is not. If not, I don't see how you know when to fudge the speed. The same holds true for the minute hand. There is either a constant speed, or there is not.
So, perhaps you could explain just how you envision this clock working, and when you would change the speed that the servo is operating at.
I am basically trying to simulate a real clock with two servos, one for each hand (Hours and Minutes). The reason for using servos is I have multiple buttons. You press one and the clock hands instantly zips to a particular time and starts running at a normal clock time. You press another and it zips to that time and starts running etc.
Normal servos can only do 180 degrees so I am using sail winch servos to allow me a couple of rotations however they work on the basis that 600pwm is all the way left and 2500pwm is approx three/four rotations to the right. I have calculated through testing that increasing the microseconds from 1000 to 1253 gives me one full rotation on the servo (this can be done anywhere within the 600-2500 range. I picked the 1000 point because it seems to be the most reliable area in the range.
So, to get one minute on the minute hand in a minute of normal time, matching a normal clock, the servo has to move 4pwm per minute (3.9 actually but it has been rounded up) I have this working in the code shown
Simultaneous to that I need the hour hand to move. This should move 1.5pwm per minute to simulate moving from say midnight to 1 over the space of an hour, however I have rounded this up to 3pwm per two minutes due to my belief that I can't use fractions of a pwm.
What I am asking is how can I have two different servos moving incrementally by different amounts with different delays.
Also I wanted to check if it is possible to increase the microseconds in decimal fractions such as 1.5 or 3.9.
You could using floating point, or you could use a fixed point representation.
I realise this is very complicated for what is essentially a simple idea.
Here is the 'wrong code version' of what I am trying to do
Case 0: MinutePulse = MinutePulse + 4; //(increases the value by 4 every loop) ServoA.WriteMicroseconds(MinutePulse) //writes value to servo Delay (60000); // delay for 60 seconds before moving again
// In the same case 0 I need the following to happen within the same program loop (simultaneously)
HourPulse = HourPulse + 3; //(increases the value by 3 every loop) ServoB.WriteMicroseconds(HourPulse) //writes value to servo Delay (120000); // delay for 120 seconds before moving again
AWOL:
Sorry, I am fairly new to this and still learning, how would I do this, and would this cause problems with the servo, or are they ok with reading a signal of say 3.9?
Thanks
Case 0:
I'm sorry, but a case statement without the enclosing switch statement is useless. I can't figure out under what conditions you expect this code to be executed.
An alternative aproach might be to use millis to tell you how much time has elapsed and calculate hours and minutes values from that. Then use the map function to map 0-59 into 0-180 (or however you have to tweak it for your servos)and write it to the servo. For the simple case that would give you time since power up. When you go to your setpoints, you’ll have to add in the appropriate (unsigned long) number of milliseconds. No worries about timing or delays.
PaulS:
Here is the ‘wrong code version’ of what I am trying to do
Case 0:
I’m sorry, but a case statement without the enclosing switch statement is useless. I can’t figure out under what conditions you expect this code to be executed.
Sorry I cut out most of the stuff that was not relevant to what I am trying to get across. I was trying to explain the fact that I am trying to have two different delays running simultaneously within the same loop. I have many switch/ case statements working perfectly within my code at the moment, I should have left the ‘case’ out to avoid confusion.
I should have left the 'case' out to avoid confusion.
I don't think that would have helped. I still need to understand under what circumstances you want to change the speed of the motors.
By now, you should know that you can't do this. You should not have ANY delays(). Look at the blink without delay example to see how to write delay()less code.
By now, you should know that you can’t do this. You should not have ANY delays(). Look at the blink without delay example to see how to write delay()less code.
I do know this, hence the reason for asking for an alternative method. I dont really see how I could use ‘millis’ to help here, can you suggest how?.
My understanding is that Millis counts the time since the program started, however my program waits for inputs and runs other switch/modes before running my ‘clocktime loop’
The absolute simplest explanation I can think of what I trying to achieve’ is:
Within one continous loop
every 60 seconds - increase servoA pwm by 4
every 120 seconds - increase servoB pwm by 3
looped forever, (or until reset)
I am trying to understand the code for timing/updating the pwm on the two servos within the same executed loop.
The Blink Without Delay sample shows you how to time a particular event using millis(). It requires you track the required timing yourself, and execute the specific task when the appropriate amount of time has passed.
This is really the only method of timing multiple independent events.
flotilla:
I do know this, hence the reason for asking for an alternative method. I dont really see how I could use 'millis' to help here, can you suggest how?.
My understanding is that Millis counts the time since the program started, however my program waits for inputs and runs other switch/modes before running my 'clocktime loop'
The absolute simplest explanation I can think of what I trying to achieve' is:
every 60 seconds - increase servoA pwm by 4 every 120 seconds - increase servoB pwm by 3
There are tons of different ways to do this, but here's a simple one for you.
int servoA = 0;
int servoB = 0;
int counter = 0;
    delay(60);
    servoA += 4;
    counter++;
    if (count == 2) {
        servoB += 3;
        counter=0;
Obviously instead of incrementing variables you'll have to increment the PWMs themselves.
Edit: Fixed a missing semicolon. I don't actually have the editor in front of me, so I just typed that up in notepad.
Just wanted to thank you all for your patience and help. I managed to get it working with the 'millis' method as suggested. After staring at it for an hour it finally clicked into place
My code for that particular section is below for anyone who is interested (majority omitted).
Thanks Again!
(Setup declarations)
unsigned long currentMillisA = millis();  //Storage for Timer
unsigned long currentMillisB = millis();  //Storage for Timer
long previousMillisA = 0;        // Millis Counter Store
long previousMillisB = 0;        // Millis Counter Store
long StepperAinterval = 60000; // 60 seconds break time
long StepperBinterval = 120000; // 120 seconds break time
(inside void loop())
 if (MinutePulse >= 2500) mode = 10; //servo safety to stop it over-turning
 if (HourPulse >= 2500) mode = 10;
  if(CurrentMillisA - previousMillisA > StepperAinterval) {
    previousMillisA = CurrentMillisA;
  if(CurrentMillisB - previousMillisB > StepperBinterval) {
    previousMillisB = CurrentMillisB;
I'm really curious why you want the motor to run faster and faster, instead of a constant speed. Every clock I own has a motor that runs at a constant speed. I can't help but think I am missing something.
PaulS:
Hi, Increasing the PWM is not increasing the speed, it is increasing the position of the motor around the 360 degrees, for example: on the minute hand 1600pwm is midnight 1604 is one minute past 1608- two minutes past and so on. So adding 4 to the microseconds every minute is moving the servo by one minute on the clock, every minute.
The need for a different speed on the hour hand is due to it having to only cover 1/12th of the 360 degrees in an hour. My maths above for the hour hand were wrong however. It is actually 3 increments every 6 minutes, not every two.
The clock is for a theatre show where there are 6 scene changes in the show. At each scene change the stage crew press a button and the time zips to the next scene time then starts ticking away until the next button is pressed, moving it on to the next scene.
I will post the full code on a seperate post for anyone who is interested. It is not perfect and probably a little messy (I still class myself as a complete newbie to all this) It works very well at the moment and keeps proper time to within a minute which is fine for my purposes.
My apologies. For some reason, I had it in my head that you were using continuous rotation servos.
My full code for community purposes and anyone who is interested. Be gentle! I know there are probably easier ways to do this.
#include <Servo.h>
#include <SoftwareSerial.h>
Servo MinuteHand;
Servo HourHand;
// SWITCH PINS
byte setupAswitch = A0;
byte setupBswitch = A1;
byte setupCswitch = A2;
byte setupDswitch = A3;
byte setupEswitch = A4;
byte setupFswitch = A5;
byte ResetSwitch = 2;
//  SERVO PINS
int MinuteHandPin = 9;     // Control pin for servo motor
int HourHandPin = 10;
//  STORAGE VALUES
int MinutePulse; // Storage value for counting time, MinuteHand
int HourPulse; // Storage value for counting time, HourHand
long StepperAinterval = 60000; // 60 seconds break time between MINUTE movements
long StepperBinterval = 360000; // 6 minute break time between HOUR movements
byte mode; //
  Serial.begin(9600);         // connect to the serial port
  Serial.println("**********    SETTING UP CLOCK CIRCUIT    **********"); //saying how it is
 //  SWITCH SETUP
 pinMode      (setupAswitch, INPUT); // set up the various push switches
 digitalWrite (setupAswitch, HIGH);  // turn on internl pullup
 pinMode      (setupBswitch, INPUT);
 digitalWrite (setupBswitch, HIGH);
 pinMode      (setupCswitch, INPUT);
 digitalWrite (setupCswitch, HIGH);
 pinMode      (setupDswitch, INPUT);
 digitalWrite (setupDswitch, HIGH);
 pinMode      (setupEswitch, INPUT);
 digitalWrite (setupEswitch, HIGH);
 pinMode      (setupFswitch, INPUT);
 digitalWrite (setupFswitch, HIGH);
 pinMode      (ResetSwitch, INPUT);
 digitalWrite (ResetSwitch, HIGH);
 // SERVO SETUP
 MinuteHand.attach(MinuteHandPin);  //Connects servo to relevent pin
 HourHand.attach(HourHandPin);
 // SET BOTH SERVOS TO 'MIDNIGHT'
 MinuteHand.writeMicroseconds(1600);  /// SET to 12.00
 HourHand.writeMicroseconds(1600);  /// SET to 12.00
 // START MILLIS TIMER
 //unsigned long CurrentMillisA = millis();  //Storage for Timer NOT SURE IF RIGHT ONE!!!
Serial.println("WAITING FOR INPUT");
if ( mode == 0 && digitalRead (setupAswitch) == LOW){ mode = 1;}
if ( mode == 0 && digitalRead (setupBswitch) == LOW){ mode = 2;}
if ( mode == 0 && digitalRead (setupCswitch) == LOW){ mode = 3;}
if ( mode == 0 && digitalRead (setupDswitch) == LOW){ mode = 4;}
if ( mode == 0 && digitalRead (setupEswitch) == LOW){ mode = 5;}
if ( mode == 0 && digitalRead (setupFswitch) == LOW){ mode = 6;}
if ( mode == 0 && digitalRead (ResetSwitch) == LOW){ mode = 9;} //reset all
if ( mode == 1 && digitalRead (ResetSwitch) == LOW){ mode = 9;} //reset all
if ( mode == 2 && digitalRead (ResetSwitch) == LOW){ mode = 9;} //reset all
if ( mode == 3 && digitalRead (ResetSwitch) == LOW){ mode = 9;} //reset all
if ( mode == 4 && digitalRead (ResetSwitch) == LOW){ mode = 9;} //reset all
if ( mode == 5 && digitalRead (ResetSwitch) == LOW){ mode = 9;} //reset all
if ( mode == 6 && digitalRead (ResetSwitch) == LOW){ mode = 9;} //reset all
if ( mode == 7 && digitalRead (ResetSwitch) == LOW){ mode = 9;} //reset all
////PROGRAM VARIABLES/SERVO SETUPS
switch (mode){
case 0:  // Do Nothing and Wait for input
case 1:  // Set Clock start position A
 MinutePulse = 1600;  // sets the stored Minute value to match the time
 HourPulse = 1600;   //sets the stored Hour value to match the time set
 MinuteHand.writeMicroseconds(MinutePulse); // sets Time A min
 HourHand.writeMicroseconds(HourPulse);  // sets Time A hour
 delay (1000);
 Serial.println("TICKING 1");
 previousMillisA = 0; //Reset Millis Counter A
 previousMillisB = 0; //Reset Millis Counter B
 mode= 7;
case 2:  // Set Clock start position B
 delay (1000);
 Serial.println("TICKING 2");
 mode= 7;
case 3:  // Set Clock start position C
 delay (1000);
 Serial.println("TICKING 3");
 mode= 7;
case 4:  // Set Clock start position D
 delay (1000);
 Serial.println("TICKING 4");
 mode= 7;
case 5:  // Set Clock start position E
 delay (1000);
 Serial.println("TICKING 5");
 mode= 7;
case 6:  // Set Clock start position F
 delay (1000);
 Serial.println("TICKING 6");
 mode= 7;
 if (MinutePulse >= 2495) mode = 10; //servo safety to stop it over-turning
 if (HourPulse >= 2495) mode = 10;
 // Serial.println(CurrentMillisA);
 // Serial.println(CurrentMillisB);
  if(CurrentMillisA - previousMillisB > StepperBinterval) {
    previousMillisB = CurrentMillisA;
    HourPulse = HourPulse + 2;
case 9:  //  RESET THE PROGRAM
Serial.println("RESETTING & JOGGING");
 MinuteHand.writeMicroseconds(1700); // Jogs the motor to ensure a 'midnight'
 HourHand.writeMicroseconds(1700);
 delay (1000);
 MinuteHand.writeMicroseconds(1600); // Jogs the motor
MinutePulse = 1600;  // resets values
HourPulse = 1600;
Serial.print("HOUR PWM VALUE IS RESET TO MIDNIGHT");
Serial.print("MINUTE PWM VALUE IS RESET TO MIDNIGHT");
delay (1000);
mode = 0;
case 10:  //  SERVO OVERREACH
Serial.println("******   BWEEP SERVO OVERREACH   *******");
Serial.print("SERVO OR PWM VALUE IS ");
delay (3000);
MinutePulse = 1600;  // resets values to midnight
HourPulse = 1600;
mode = 0;
} // end switch
} // end loop
These should be:
long StepperAinterval = 60000UL; // 60 seconds break time between MINUTE movements
long StepperBinterval = 360000UL; // 6 minute break time between HOUR movements
Good names. It is very easy to see what you are doing.
I’m not a fan of magic numbers. I’d do something like this:
 // Set initial position for servos
#define MIDNITE 1600
 MinuteHand.writeMicroseconds(MIDNITE);  /// SET to 12.00
 HourHand.writeMicroseconds(MIDNITE);  /// SET to 12.00
That way, if you need to change the value (to 1601 or 1599, for instance), you only need to do it in one place.
Using a nested if test would be better:
if(mode == 0)
   if (digitalRead (setupAswitch) == LOW){ mode = 1;}
   if (digitalRead (setupBswitch) == LOW){ mode = 2;}
   if (digitalRead (setupCswitch) == LOW){ mode = 3;}
   if (digitalRead (setupDswitch) == LOW){ mode = 4;}
   if (digitalRead (setupEswitch) == LOW){ mode = 5;}
   if (digitalRead (setupFswitch) == LOW){ mode = 6;}
Again, a little restructuring here leads to more readable code:
if(digitalRead (ResetSwitch) == LOW)
   if(mode > 0 && mode <= 7)
      mode = 9;
(and a lot less of it…)
I don’t see how cases 2 through 6 differ from each other. Can you point out what I missed?
Thanks Paul, that is very helpful
PaulS: long StepperAinterval = 60000; // 60 seconds break time between MINUTE movements          long StepperBinterval = 360000; // 6 minute break time between HOUR movements
These should be:
Just wondered what the UL is for? It seems to work fine without it.
One issue I do have however is that when Case 7 starts it is not always exactly 60 seconds before the first value is written to the motor, it seems to be random as to how long after pressing the switch to the first write, I am assuming it is something to do with the millis count not being zero when the case 7 starts to run.
After the first write it does stick strictly to the right timings for each motor so it is not too much of an issue and it is never seems to be more than a minute, Just a bit annoying.
Case 1-6 are all the same because the different 'start times' have not been entered yet. When I get the timings for the show these will all be set to different start points.
Thanks again for your help
